Datasheet Texas Instruments 84085012A — Даташит
СерияSN54HC245
Модель84085012A
Восьмеричные шинные трансиверы с выходами с 3 состояниями 20-LCCC от -55 до 125
SNx4HC245 Octal Bus Transceivers With 3-State Outputs datasheet
PDF, 2.1 Мб, Версия: E, Файл опубликован: 30 сен 2015
Pin202020
Package TypeFKFKFK
Industry STD TermLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY111
CarrierTUBETUBETUBE
Маркировка245FK84085012ASNJ54HC
Width (мм)8.898.898.89
Length (мм)8.898.898.89
Thickness (мм)1.831.831.83
Pitch (мм)1.271.271.27
Max Height (мм)2.032.032.03
Bits8
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Schmitt TriggerNo
Technology FamilyHC
VCC(Max)6 В
VCC(Min)2 В
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceivers
На английском языке: Datasheet Texas Instruments 84085012A
