Datasheet Texas Instruments ADS5400IPZPR — Даташит
| Серия | ADS5400 |
| Модель | ADS5400IPZPR |
12-битный аналого-цифровой преобразователь (АЦП) 1,0-GSPS 100-HTQFP от -40 до 85
ADS5400 12-Bit, 1-GSPS Analog-to-Digital Converter datasheet
PDF, 2.3 Мб, Версия: C, Файл опубликован: 15 янв 2016
Купить ADS5400IPZPR на РадиоЛоцман.Цены — от 38 053 до 128 380 ₽12 предложений от 12 поставщиков IC ADC 12BIT PIPELINED 100HTQFP. 12 Bit Analog to Digital Converter 1 Input 1 Pipelined 100-HTQFP (14x14). Data Acquisition - Analog... | |||
| ADS5400IPZPR Texas Instruments | 38 053 ₽ | ||
| ADS5400IPZPR Texas Instruments | 39 316 ₽ | ||
| ADS5400IPZPR Texas Instruments | 47 735 ₽ | ||
| ADS5400IPZPR Texas Instruments | 128 380 ₽ | ||
| Pin | 100 |
| Package Type | PZP |
| Industry STD Term | HTQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 1000 |
| Carrier | LARGE T&R |
| Маркировка | ADS5400I |
| Width (мм) | 14 |
| Length (мм) | 14 |
| Thickness (мм) | 1 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| # Input Channels | 1 |
| Analog Input BW | 2150 МГц |
| Архитектура | Pipeline |
| DNL(Max) | 2 +/-LSB |
| DNL(Typ) | 0.7 +/-LSB |
| ENOB | 9.3 Bits |
| INL(Max) | 4.5 +/-LSB |
| INL(Typ) | 2 +/-LSB |
| Input Buffer | Yes |
| Input Range | 2 Vp-p |
| Interface | Parallel LVDS |
| Package Group | HTQFP |
| Package Size: mm2:W x L | 100HTQFP: 256 mm2: 16 x 16(HTQFP) PKG |
| Power Consumption(Typ) | 2200 mW |
| Rating | Catalog |
| Reference Mode | Ext,Int |
| Разрешение | 12 Bits |
| SFDR | 75 дБ |
| SINAD | 58 дБ |
| SNR | 59.1 дБ |
| Sample Rate(Max) | 1000 MSPS |
- Evaluation Modules & Boards: ADS5400EVM
ADS5400 12-bit, 1.0-GSPS Analog-to-Digital Converter Evaluation Module
- Input Impedance Measurement Using ADC FFT DataPDF, 275 Кб, Файл опубликован: 11 янв 2011
Texas Instruments has introduced a family of high-speed analog-to-digital converters (ADCs) suited tomeet the demand for high-speed and high-IF sampling systems. To achieve the highest overall system performance, an analog front-end circuit with an antialiasing filter must drive the ADC with the highestpossible dynamic range and lowest distortions. One important parameter of the front-end circ - High-Speed Analog-to-Digital Converter BasicsPDF, 1.1 Мб, Файл опубликован: 11 янв 2012
The goal of this document is to introduce a wide range of theories and topics that are relevant tohigh-speed analog-to-digital converters (ADC). This document provides details on sampling theorydata-sheet specifications ADC selection criteria and evaluation methods clock jitter and other commonsystem-level concerns. In addition some end-users will want to extend the performance capabil - CDCE62005 as Clock Solution for High-Speed ADCsPDF, 805 Кб, Файл опубликован: 4 сен 2008
TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527 which is capable of sampling up to 210 MSPS. To realize the full potential of these high-performance products it is imperative to provide a low phase noise clock source. The CDCE62005 clock synthesizer chip offers a real-world clocking solution to meet these stringent requirements - Design Considerations for Avoiding Timing Errors during High-Speed ADC, LVDS Dat (Rev. A)PDF, 2.0 Мб, Версия: A, Файл опубликован: 22 май 2015
- Why Use Oversampling when Undersampling Can Do the Job? (Rev. A)PDF, 1.2 Мб, Версия: A, Файл опубликован: 19 июл 2013
- Smart Selection of ADC/DAC Enables Better Design of Software-Defined RadioPDF, 376 Кб, Файл опубликован: 28 апр 2009
This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs and the DAC5688 from Texas Instruments fit properly for SDR designs. - Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir - Phase Noise Performance and Jitter Cleaning Ability of CDCE72010PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig - CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital ConvertersPDF, 424 Кб, Файл опубликован: 8 июн 2008
Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
Серия: ADS5400 (2)
- ADS5400IPZP ADS5400IPZPR
- Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
