Оптопары и оптореле Megawin
Datasheet Texas Instruments LM2598SX-12/NOPB — Даташит
СерияLM2598
МодельLM2598SX-12/NOPB
SIMPLE SWITCHER® Понижающий импульсный стабилизатор от 4,5 до 40 В, 1 А 7-DDPAK/TO-263 от -40 до 125
LM2598 SIMPLE SWITCHERВ® Power Converter 150-kHz 1-A Step-Down Voltage Regulator, With Features datasheet
PDF, 2.7 Мб, Версия: D, Файл опубликован: 31 май 2016
Pin77
Package TypeKTWKTW
Industry STD TermTO-263TO-263
JEDEC CodeR-PSFM-GR-PSFM-G
Package QTY500500
CarrierLARGE T&RLARGE T&R
Маркировка-12 P+LM2598S
Width (мм)8.898.89
Length (мм)10.110.1
Thickness (мм)4.444.44
Pitch (мм)1.271.27
Max Height (мм)4.654.65
Control ModeVoltage Mode
Duty Cycle(Max)100 %
Iout(Max)1 A
Iq(Typ)5 мА
Package GroupDDPAK/TO-263
Regulated Outputs1
Special FeaturesPower Good
Switching Frequency(Max)173 kHz
Switching Frequency(Min)110 kHz
ТипConverter
Vin(Max)40 В
Vin(Min)4.5 В
Vout(Max)37 В
Vout(Min)3.3 В
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Simple Techniques Minimize Cross-Coupling in Distributed Power Systems
    PDF, 335 Кб, Файл опубликован: 21 мар 2007
  • AN-1081 Low-Cost Low-Parts-Count DC/DC Converter With Multiple Outputs (Rev. B)
    PDF, 124 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application report describes a simple low cost, low parts-count multiple output DC/DC converterbased on the LM2596 five terminal step-down switching regulator. The circuit described provides multipleoutput voltages (positive and negative) with good regulation using a step-down converter circuit withflyback windings. It uses only one switching regulator IC.
LM2598SX12/NOPB, LM2598SX 12/NOPB
На английском языке: Datasheet Texas Instruments LM2598SX-12/NOPB
