Datasheet Texas Instruments UC2907J — Даташит
СерияUC2907
МодельUC2907J
Контроллер распределения нагрузки 16-CDIP от -40 до 85
Load Share Controller datasheet
PDF, 351 Кб, Версия: C, Файл опубликован: 9 янв 2002
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Approx. Price (US$)2.76 | 1ku
Operating Supply Current(mA)6
Operating Supply(Max)(V)35
Operating Supply(Min)(V)4.5
Operating Temperature Range(C)-40 to 85
Package GroupPDIP
SOIC
See datasheet (CDIP)
Share BusSingle-Ended
Special FeaturesOn-Board Reference
Startup Current(uA)3000
RoHSНе совместим
  • Evaluation Modules & Boards: UCC39002EVM
    UCC39002 Evaluation Module
  • U-129 UC3907 Load Share IC Simplifies Parallel Power Supply Design
    PDF, 251 Кб, Файл опубликован: 5 сен 1999
    The UC3907 family of Load Share Controller ICs provides all the necessary features to allow multiple independent power modules to be paralleled, so each module supplies only its proportionate share to total load current. Many power supply manufacturers have found it economically feasible to make standard modular power supplies which are easily paralleled for higher current applications. If speci
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Load Share
На английском языке: Datasheet Texas Instruments UC2907J
