Datasheet Texas Instruments 81021012A — Даташит
| Серия | SN54LS629 |
| Модель | 81021012A |
Генераторы, управляемые напряжением 20-LCCC от -55 до 125
Voltage-Controlled Oscillators datasheet
PDF, 947 Кб, Файл опубликован: 1 мар 1988
Купить 81021012A на РадиоЛоцман.Цены — от 1 961 до 2 754 ₽, Oscillator VCO 1.1MHz to 25MHz 45pF Squarewave 50% 5V 20Pin CLLCC SMD Tube | |||
| 81021012A Texas Instruments | 1 961 ₽ | ||
| 81021012A Texas Instruments | 2 754 ₽ | ||
| 81021012A Texas Instruments | по запросу | ||
| Pin | 20 | 20 | 20 |
| Package Type | FK | FK | FK |
| Industry STD Term | LCCC | LCCC | LCCC |
| JEDEC Code | S-CQCC-N | S-CQCC-N | S-CQCC-N |
| Package QTY | 1 | 1 | 1 |
| Carrier | TUBE | TUBE | TUBE |
| Маркировка | 629FK | SNJ54LS | 81021012A |
| Width (мм) | 8.89 | 8.89 | 8.89 |
| Length (мм) | 8.89 | 8.89 | 8.89 |
| Thickness (мм) | 1.83 | 1.83 | 1.83 |
| Pitch (мм) | 1.27 | 1.27 | 1.27 |
| Max Height (мм) | 2.03 | 2.03 | 2.03 |
| Mechanical Data | Скачать | Скачать | Скачать |
| Bits | 2 |
| F @ Nom Voltage(Max) | 35 Mhz |
| ICC @ Nom Voltage(Max) | 55 мА |
| Тип входа | TTL |
| Рабочий диапазон температур | от -55 до 125 C |
| Output Drive (IOL/IOH)(Max) | 24/-1.2 мА |
| Тип выхода | TTL |
| Package Group | LCCC |
| Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
| Rating | Military |
| Schmitt Trigger | No |
| Technology Family | LS |
| VCC(Max) | 5.25 В |
| VCC(Min) | 4.75 В |
| Voltage(Nom) | 5 В |
| tpd @ Nom Voltage(Max) | 15 нс |
| RoHS | See ti.com |
- Live InsertionPDF, 150 Кб, Файл опубликован: 1 окт 1996
Many applications require the ability to exchange modules in electronic systems without removing the supply voltage from the module (live insertion). For example an electronic telephone exchange must always remain operational even during module maintenance and repair. To avoid damaging components additional circuitry modifications are necessary. This document describes in detail the phenomena tha - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Designing with the SN54/74LS123 (Rev. A)PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
Серия: SN54LS629 (7)
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Phase-Locked-Loop (PLL)Products/Oscillators
