Datasheet Texas Instruments LM3444MA/NOPB — Даташит
СерияLM3444
МодельLM3444MA/NOPB
Автономный светодиодный драйвер AC-DC 8-SOIC от -40 до 125
LM3444 AC-DC Offline LED Driver datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 31 дек 2015
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9595
CarrierTUBETUBE
МаркировкаMAL3444
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Dimming MethodAnalog
Входное напряжениеAC/DC Type
Iout(Max)2 A
Iq(Typ)1.58 мА
Power Factor CorrectionActive,Passive Min
Regulated Outputs1
Special FeaturesAdjustable Switch Frequency,Thermal Shutdown
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)30 kHz
TopologyBuck,Flyback
ТипInductive
Vin(Max)13 В
Vin(Min)8 В
Vout(Max)60 В
Vout(Min)9 В
Vref0.75 В
  • Evaluation Modules & Boards: LM3444MR16BBRB
    LM3444 Buck-Boost Topology MR16 LED Bulb Reference Design
  • Evaluation Modules & Boards: LM3444-230VFLBK
    LM3444 -230VAC, 8W Isolated Flyback LED Driver (no dim) Evaluation Board
  • Evaluation Modules & Boards: LM3444MR16BSTRB
    LM3444 Boost Topology MR16 LED Bulb Reference Design
  • Evaluation Modules & Boards: LM3444-120VFLBK
    LM3444 -120VAC, 8W Isolated Flyback LED Driver (no dim) Evaluation Board
  • Evaluation Modules & Boards: LM3444-EDSNEV
    LM3444 A19 Edison Retrofit LED Driver (no dim) Evaluation Board
  • An Improved Line Regulation Solution Used in LM3444/5 Non-Isolated LED Lighting
    PDF, 1.0 Мб, Файл опубликован: 25 окт 2012
  • AN-2097 LM3444 - 230VAC, 8W Isolated Flyback LED Driver (Rev. F)
    PDF, 5.4 Мб, Версия: F, Файл опубликован: 1 май 2013
    This is a four-layer board using the bottom and top layer for component placement. The demonstration board can be modified to adjust the LED forward current, the number of series connected LEDs that are driven and the switching frequency.
  • AN-2082 LM3444 -120VAC, 8W Isolated Flyback LED Driver (Rev. E)
    PDF, 6.4 Мб, Версия: E, Файл опубликован: 1 май 2013
    This demonstration board highlights the performance of a LM3444 based Flyback LED driver solution that can be used to power a single LED string consisting of 4 to 8 series connected LEDs from an 90 VRMS to 135 VRMS, 60 Hz input power supply. The key performance characteristics under typical operating conditions are summarized in this application note.
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM3444 (4)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3444MA/NOPB
