Datasheet Texas Instruments THS6062CDR — Даташит
СерияTHS6062
МодельTHS6062CDR
Малошумящий двойной дифференциальный приемник ADSL 8-SOIC
Low-Noise ADSL Dual Differential Receiver datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 15 окт 2007
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic(dBc)91
3rd Harmonic(dBc)109
@ MHz1
Acl, min spec gain(V/V)1
Additional FeaturesDecompensated
Approx. Price (US$)3.68 | 1ku
АрхитектураBipolar
Voltage FB
BW @ Acl(MHz)100
CMRR(Min)(dB)85
CMRR(Typ)(dB)95
GBW(Typ)(MHz)100
Input Bias Current(Max)(pA)10000000
Iq per channel(Max)(mA)9
Iq per channel(Typ)(mA)7.5
Number of Channels(#)2
Offset Drift(Typ)(uV/C)20
Operating Temperature Range(C)-40 to 85
0 to 70
Output Current(Typ)(mA)90
Package Size: mm2:W x L (PKG)8SOIC: 29 mm2: 6 x 4.9(SOIC)
Rail-to-RailNo
Slew Rate(Typ)(V/us)100
Total Supply Voltage(Max)(+5V=5, +/-5V=10)33
Total Supply Voltage(Min)(+5V=5, +/-5V=10)4.5
Vn at Flatband(Typ)(nV/rtHz)1.6
Vos (Offset Voltage @ 25C)(Max)(mV)6
RoHSНе совместим
  • Evaluation Modules & Boards: THS6062EVM
    THS6062 High Speed Amplifier Evaluation Module
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
На английском языке: Datasheet Texas Instruments THS6062CDR
