Datasheet Texas Instruments LM6132BIN/NOPB — Даташит
СерияLM6132
МодельLM6132BIN/NOPB
Двойной операционный усилитель ввода-вывода малой мощности 10 МГц с Rail-to-Rail I/O 8-PDIP от -40 до 85
LM6132/LM6134 Dual and Quad Low Power 10В MHz Rail-to-Rail I/O Operational Amplifiers datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 5 сен 2014
30 предложений от 18 поставщиков
LM6132BIN/NOPB
172 ₽
LM6132BIN/NOPB
310 ₽
LM6132BIN/NOPB
от 677 ₽
SUV System
LM6132BIN/NOPB
Pin88
Package TypePP
Industry STD TermPDIPPDIP
JEDEC CodeR-PDIP-TR-PDIP-T
Package QTY4040
CarrierTUBETUBE
МаркировкаLM6132BIN
Width (мм)6.356.35
Length (мм)9.819.81
Thickness (мм)3.93.9
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)75 дБ
CMRR(Typ)107 дБ
GBW(Typ)10 МГц
Input Bias Current(Max)140000 pA
Iq per channel(Max)0.45 мА
Iq per channel(Typ)0.36 мА
Количество каналов2
Offset Drift(Typ)5 uV/C
Output Current(Typ)4.3 мА
Package GroupPDIP
Rail-to-RailIn,Out
Slew Rate(Typ)14 V/us
Total Supply Voltage(Max)24 +5V=5, +/-5V=10
Vn at 1kHz(Typ)27 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • AN-1237 RSDSв„ў Flat Panel Display Design Guidelines Part 2 (Rev. A)
    PDF, 194 Кб, Версия: A, Файл опубликован: 6 май 2013
    This application report presents part 2 of the flat panel display design guidelines.
  • AN-1234 RSDSв„ў Flat Panel Display Design Guidelines Part 1 (Rev. A)
    PDF, 245 Кб, Версия: A, Файл опубликован: 6 май 2013
    This application report outlines the total system solution that Texas Instruments provides for flat panel displays (FPDs). The described design uses an reduced swing differential signaling (RSDS) interface technology for reduced power, reduced board size, reduced component count, and reduced EMI. This document is currently applicable to XGA and SXGA notebook and monitor applications.
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
На английском языке: Datasheet Texas Instruments LM6132BIN/NOPB
