Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LM22677QTJE-ADJ/NOPB — Даташит
СерияLM22677-Q1
МодельLM22677QTJE-ADJ/NOPB
5A ПРОСТОЙ ПЕРЕКЛЮЧАТЕЛЬ, регулятор понижения напряжения.
LM22677/-Q1 42-V, 5-A SIMPLE SWITCHER, Step-Down Voltage Regulator With Features datasheet
PDF, 1.3 Мб, Версия: O, Файл опубликован: 11 авг 2015
с синхронизацией или регулируемой частотой переключения 7-TO-263 от -40 до 125
Pin77
Package TypeNDRNDR
Industry STD TermTO-263TO-263
JEDEC CodeR-MSFM-LR-MSFM-L
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаLM22677QTJ-ADJ
Width (мм)9.859.85
Length (мм)10.1610.16
Thickness (мм)22
Pitch (мм)1.271.27
Max Height (мм)2.252.25
Control ModeVoltage Mode
Duty Cycle(Max)90 %
Iout(Max)5 A
Iq(Typ)3.4 мА
Package GroupTO-263
RatingAutomotive
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)42 В
Vin(Min)4.5 В
Vout(Max)37 В
Vout(Min)1.285 В
  • Evaluation Modules & Boards: LM22677EVAL
    LM22677 5A SIMPLE SWITCHER Regulator w/ Freq Adj or Synch and Precision Enable EVM
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
Серия: LM22677-Q1 (3)
LM22677QTJEADJ/NOPB, LM22677QTJE ADJ/NOPB
На английском языке: Datasheet Texas Instruments LM22677QTJE-ADJ/NOPB
Публикации по теме
