Datasheet Texas Instruments TPS7A8500RGRR — Даташит
СерияTPS7A85
МодельTPS7A8500RGRR
High-Current (4A), High-Accuracy (1%), Low-Noise (4.4ОјVRMS), LDO Voltage Regulator 20-VQFN -40 to 125
TPS7A85 High-Current (4 A), High-Accuracy (1%), Low-Noise (4.4 µVRMS), LDO Voltage Regulator datasheet
PDF, 2.6 Мб, Версия: A, Файл опубликован: 5 фев 2016
30 предложений от 13 поставщиков
Чип стабилизации напряжения, High-Current (4A), High-Accuracy (1%), Low-Noise (4.4 μVRMS), LDO Voltage Regulator 20-VQFN -40℃ to 125℃
Рутоника
TPS7A8500RGRR
306 ₽
Зенер
Россия и страны ТС
TPS7A8500RGRR
от 359 ₽
TPS7A8500RGRR
1 406 ₽
TPS7A8500RGRR
Pin20
Package TypeRGR
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Маркировка11DI
Width (мм)3.5
Length (мм)3.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Точность1 %
Iout(Max)4 A
Iq(Typ)2.8 мА
Noise4.4 uVrms
Output Capacitor TypeCeramic
Output OptionsAdjustable Output,Programmable Output
PSRR @ 100KHz25 дБ
Package GroupVQFN
Package Size: mm2:W x L20VQFN: 12 mm2: 3.5 x 3.5(VQFN) PKG
Regulated Outputs1
Special FeaturesEnable,Output Discharge,Power Good,Soft Start
Thermal Resistance ОёJA35 В°C/W
Vdo(Typ)150 мВ
Vin(Max)6.5 В
Vin(Min)1.1 В
Vout(Max)5 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: TPS7A85EVM-754
    TPS7A85 High-Current (4A), High-Accuracy, Low-Noise, LDO Voltage Regulator Evaluation Module
  • Evaluation Modules & Boards: DAC38RF89EVM
    DAC38RF89 Dual-Channel, 14-Bit, 8.4GSPS, 1x-24x Interpolating, 5 & 7.5 GHz PLL DAC Evaluation Module
  • Evaluation Modules & Boards: DAC38RF87EVM
    DAC38RF87 Dual-Channel, 14-Bit, 6.2-GSPS, 6x-24x Interpolating, 6-GHz GSM PLL DAC Evaluation Module
  • Evaluation Modules & Boards: DAC38RF80EVM
    DAC38RF80 Dual-Channel, 14-Bit, 9-GSPS, 6x-24x Interpolating, 6 & 9 GHz PLL DAC Evaluation Module
  • Evaluation Modules & Boards: DAC38RF82EVM
    DAC38RF82 Dual-Channel, 14-Bit, 9-GSPS, 1x-24x Interpolating, 6 & 9 GHz PLL DAC Evaluation Module
  • Evaluation Modules & Boards: TSW40RF80EVM
    2T2R RF-Sampling Transceiver With Dual 14-Bit 3GSPS ADC, Dual 14-Bit 9GSPS DAC and Clocking Solution
Серия: TPS7A85 (2)
На английском языке: Datasheet Texas Instruments TPS7A8500RGRR
