Datasheet Texas Instruments 5962-87804012A — Даташит
СерияSN54AS21
Модель5962-87804012A
Двойные логические элементы положительного И с 4 входами 20-LCCC от -55 до 125
Datasheet
TSP
Pin20
Package TypeFK
Industry STD TermLCCC
JEDEC CodeS-CQCC-N
Width (мм)8.89
Length (мм)8.89
Thickness (мм)1.83
Max Height (мм)2.03
RoHSНе совместим
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Live Insertion
Серия: SN54AS21 (4)
  • Semiconductors > Space & High Reliability > Logic Products > Gate Products
596287804012A, 5962 87804012A
На английском языке: Datasheet Texas Instruments 5962-87804012A
