Datasheet Texas Instruments V62/03645-01XE — Даташит
| Серия | SN74AHC02-EP |
| Модель | V62/03645-01XE |
Усовершенствованный продукт, четверной, 2 входа, вентили «положительный-нор» 14-TSSOP от -55 до 125
Купить V62/03645-01XE на РадиоЛоцман.Цены — от 43 до 176 ₽Микросхема Логический чип, NOR Gate 4Element 2IN CMOS 14Pin TSSOP T/R | |||
| V62/03645-01XE Texas Instruments | 43 ₽ | ||
| V62/03645-01XE Texas Instruments | 176 ₽ | ||
| V62/03645-01XE Texas Instruments | по запросу | ||
| V62/03645-01XE | по запросу | ||
| Pin | 14 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | AHC02EP |
| Width (мм) | 4.4 |
| Length (мм) | 5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 4 |
| F @ Nom Voltage(Max) | 110 Mhz |
| ICC @ Nom Voltage(Max) | 0.02 мА |
| Тип входа | CMOS |
| Рабочий диапазон температур | от -55 до 125 C |
| Output Drive (IOL/IOH)(Max) | 50/-50 мА |
| Тип выхода | CMOS |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
| Rating | HiRel Enhanced Product |
| Schmitt Trigger | No |
| Technology Family | AHC |
| VCC(Max) | 5.5 В |
| VCC(Min) | 2 В |
| tpd @ Nom Voltage(Max) | 13,8.5 нс |
- Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
Серия: SN74AHC02-EP (2)
- SN74AHC02MPWREP V62/03645-01XE
- Semiconductors > Space & High Reliability > Logic Products > Gate Products
V62/0364501XE, V62/03645 01XE
