Datasheet Texas Instruments SNJ54AHC541J — Даташит
СерияSN54AHC541
МодельSNJ54AHC541J
Восьмеричные буферы/драйверы с выходами с 3 состояниями 20-CDIP от -55 до 125
SNx4AHC541 Octal Buffers/Drivers With 3-State Outputs datasheet
PDF, 1.5 Мб, Версия: O, Файл опубликован: 29 сен 2015
Микросхема Логический чип, Buffer/Line Driver 8CH Non-Inverting 3-ST CMOS 20Pin CDIP Tube
Microfind
SNJ54AHC541J
1 588 ₽
SNJ54AHC541J
1 822 ₽
SNJ54AHC541J
Hi-Tech Circuit Group
SNJ54AHC541J
Pin202020
Package TypeJJJ
Industry STD TermCDIPCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-TR-GDIP-T
Package QTY111
CarrierTUBETUBETUBE
МаркировкаA5962-9685701QRSNJ54AHC541J
Width (мм)6.926.926.92
Length (мм)24.224.224.2
Thickness (мм)4.574.574.57
Pitch (мм)2.542.542.54
Max Height (мм)5.085.085.08
Bits8
Тип входаCMOS
Тип выходаCMOS
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyAHC
VCC(Max)5.5 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
RoHSSee ti.com
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
На английском языке: Datasheet Texas Instruments SNJ54AHC541J
