Datasheet Texas Instruments SN65HVD10QDG4 — Даташит
СерияSN65HVD10
МодельSN65HVD10QDG4
Полудуплексный трансивер RS-485, 3,3 В, 8-SOIC, 32 Мбит/с, от -40 до 125
SNx5HVD1x 3.3-V RS-485 Transceivers datasheet
PDF, 1.2 Мб, Версия: O, Файл опубликован: 1 фев 2017
IC TRANSCEIVER HALF 1/1 8SOIC. 1/1 Transceiver Half RS422, RS485 8-SOIC. Interface - Drivers, Receivers, Transceivers
SN65HVD10QDG4
135 ₽
Рутоника
SN65HVD10QDG4
205 ₽
SN65HVD10QDG4
273 ₽
SUV System
SN65HVD10QDG4
Package TypeD
Package QTY75
МаркировкаVP10Q
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Common Mode Range-7 to 12
DuplexHalf
Fail SafeIdle,Open,Short
Fault Protection-9 to 14 В
HBM ESD16 kV
ICC(Max)15.5 мА
IEC 61000-4-2 ContactN/A +/- kV
IsolatedNo
No. of RX1
No. of TX1
Number of Nodes64
Signaling Rate(Max)32 Mbps
Supply Voltage(s)(Nom)3.3 В
  • Evaluation Modules & Boards: RS485-HF-DPLX-EVM
    RS-485 Half-Duplex Evaluation Module
  • Operating RS-485 Transceivers at Fast Signaling Rates
    PDF, 631 Кб, Файл опубликован: 15 ноя 2004
    The TIA/EIA-485-A standard specifies characteristics for RS-485 signaling. Most applications operate below 10 Mbps but it is often possible to signal at higher rates. This application report examines the constraints on high-speed signaling and presents results using the SN65HVD10 transceiver as one example transceiver. Our method is to measure the eye patterns at the end of a 10-m cable under vary
  • The RS-485 Unit Load and Maximum Number of Bus Connections
    PDF, 197 Кб, Файл опубликован: 15 мар 2004
    The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
На английском языке: Datasheet Texas Instruments SN65HVD10QDG4
