Datasheet Texas Instruments SN74AS1034AD — Даташит
СерияSN74AS1034A
МодельSN74AS1034AD
Шестигранные драйверы 14-SOIC от 0 до 70
Hex Drivers datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 1 янв 1995
Pin14
Package TypeD
Package QTY50
МаркировкаAS1034A
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Bits6
F @ Nom Voltage(Max)125 Mhz
ICC @ Nom Voltage(Max)0.014 мА
Output Drive (IOL/IOH)(Max)-48/48 мА
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)6 нс
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
На английском языке: Datasheet Texas Instruments SN74AS1034AD
