Datasheet Texas Instruments SN74LVCH244ADBLE — Даташит
СерияSN74LVCH244A
МодельSN74LVCH244ADBLE
Восьмеричный буфер/драйвер с выходами с 3 состояниями 20-SSOP от -40 до 85
SN54LVCH244A, SN74LVCH244A datasheet
PDF, 1.6 Мб, Версия: O, Файл опубликован: 5 фев 2007
Pin20
Package TypeDB
Industry STD TermSSOP
Width (мм)5.3
Length (мм)7.2
Thickness (мм)1.95
Max Height (мм)2
Approx. Price (US$)0.12 | 1ku
Bits(#)8
F @ Nom Voltage(Max)(Mhz)100
ICC @ Nom Voltage(Max)(mA)0.01
Тип входаTTL/CMOS
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)-24/24
Тип выходаLVTTL
Package GroupSSOP
Package Size: mm2:W x L (PKG)20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP)
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)(V)3.6
VCC(Min)(V)1.65
Voltage(Nom)(V)1.8
2.5
2.7
3.3
tpd @ Nom Voltage(Max)(ns)6.9
5.9
RoHSНе совместим
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
На английском языке: Datasheet Texas Instruments SN74LVCH244ADBLE
