Datasheet Texas Instruments V62/03667-01XE — Даташит
| Серия | SN74LVTH244A-EP |
| Модель | V62/03667-01XE |
Усовершенствованный продукт Восьмеричные буферы/драйверы с напряжением 3,3 В и выходами с 3 состояниями 20-SSOP от -40 до 125
SN74LVTH244A-EP datasheet
PDF, 436 Кб, Версия: C, Файл опубликован: 28 окт 2003
Купить V62/03667-01XE на РадиоЛоцман.Цены — от 58 до 59 ₽Микросхема Логический чип, Enhanced Product 3.3V Abt Octal Buffers/Drivers With 3-State Outputs 20-SSOP -40℃ to 125℃ | |||
| V62/03667-01XE Texas Instruments | 58 ₽ | ||
| V62/03667-01XE Texas Instruments | 59 ₽ | ||
| V62/03667-01XE Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | DB |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | LH244AEP |
| Width (мм) | 5.3 |
| Length (мм) | 7.2 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | .65 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| Bits | 8 |
| Тип входа | TTL |
| Тип выхода | LVTTL |
| Package Group | SSOP |
| Package Size: mm2:W x L | 20SSOP: 56 mm2: 7.8 x 7.2(SSOP) PKG |
| Rating | HiRel Enhanced Product |
| Schmitt Trigger | No |
| Technology Family | LVT |
| VCC(Max) | 3.6 В |
| VCC(Min) | 2.7 В |
| Voltage(Nom) | 3.3 В |
- LVT Family Characteristics (Rev. A)PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti - LVT-to-LVTH ConversionPDF, 84 Кб, Файл опубликован: 8 дек 1998
Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVTH244A-EP (4)
- SN74LVTH244AQDBREP SN74LVTH244AQPWREP V62/03667-01XE V62/03667-01YE
- Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
V62/0366701XE, V62/03667 01XE
