Datasheet Texas Instruments THS6062IDGNRG4 — Даташит
СерияTHS6062
МодельTHS6062IDGNRG4
Малошумящий двойной дифференциальный приемник ADSL 8-MSOP-PowerPAD от -40 до 85
Low-Noise ADSL Dual Differential Receiver datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 15 окт 2007
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
МаркировкаABH
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
2nd Harmonic91 dBc
3rd Harmonic109 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesDecompensated
АрхитектураBipolar,Voltage FB
BW @ Acl100 МГц
CMRR(Min)85 дБ
CMRR(Typ)95 дБ
GBW(Typ)100 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)9 мА
Iq per channel(Typ)7.5 мА
Количество каналов2
Offset Drift(Typ)20 uV/C
Output Current(Typ)90 мА
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG
Rail-to-RailNo
Slew Rate(Typ)100 V/us
Total Supply Voltage(Max)33 +5V=5, +/-5V=10
Total Supply Voltage(Min)4.5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.9 нВ/rtГц
Vn at Flatband(Typ)1.6 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)6 мВ
  • Evaluation Modules & Boards: THS6062EVM
    THS6062 High Speed Amplifier Evaluation Module
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
На английском языке: Datasheet Texas Instruments THS6062IDGNRG4
