Datasheet Texas Instruments TLV2362IDGKR — Даташит
Серия | TLV2362 |
Модель | TLV2362IDGKR |
Двойной высокопроизводительный низковольтный операционный усилитель 8-VSSOP от -40 до 85
High-Performance Low-Voltage Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 27 июн 2007
Pin | 8 | 8 | 8 |
Package Type | DGK | DGK | DGK |
Industry STD Term | VSSOP | VSSOP | VSSOP |
JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G |
Package QTY | 2500 | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R | LARGE T&R |
Маркировка | YBL | YBS | YBU |
Width (мм) | 3 | 3 | 3 |
Length (мм) | 3 | 3 | 3 |
Thickness (мм) | .97 | .97 | .97 |
Pitch (мм) | .65 | .65 | .65 |
Max Height (мм) | 1.07 | 1.07 | 1.07 |
Additional Features | N/A |
Архитектура | Bipolar |
CMRR(Min) | 85 дБ |
CMRR(Typ) | 60 дБ |
GBW(Typ) | 7 МГц |
Input Bias Current(Max) | 150000 pA |
Iq per channel(Max) | 2.5 мА |
Iq per channel(Typ) | 1.75 мА |
Количество каналов | 2 |
Output Current(Typ) | 1.2 мА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rail-to-Rail | No |
Rating | Catalog |
Slew Rate(Typ) | 3 V/us |
Total Supply Voltage(Max) | 5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 8 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 6 мВ |
- Stability Analysis Of Voltage-Feedback Op Amps Including Compensation Technique (Rev. A)PDF, 197 Кб, Версия: A, Файл опубликован: 12 мар 2001
This report presents an analysis of the stability of voltage-feedback operational amplifiers (op amps) using circuit performance as the criteria to attain a successful design. It discusses several compensation techniques for op amps with and without internal compensation. - Conditioning a Switch-mode Power Supply Current Signal Using TI Op AmpsPDF, 61 Кб, Файл опубликован: 23 мар 2000
The switch-mode power supply primary current is often sensed using a power resistor. Using an op amp to amplify the current-sense signal can reduce cost and improve noise performance and efficiency. This report reviews the advantages of using an op amp circuit and analyzes the design criteria needed to choose the proper op amp. - Use of Rail-to-Rail Operational Amplifiers (Rev. A)PDF, 159 Кб, Версия: A, Файл опубликован: 22 дек 1999
Серия: TLV2362 (9)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > General-Purpose Op Amps
