Datasheet Texas Instruments DAC121S101WGRQV — Даташит
СерияDAC121S101QML-SP
МодельDAC121S101WGRQV
12-битный микромощный цифро-аналоговый преобразователь с выходом Rail-to-Rail 10-CFP от -55 до 125
DAC121S101QML-SP Radiation Hardened 12-Bit Micro Power Digital-to-Analog Converter With Rail-to-Rail Output datasheet
PDF, 887 Кб, Версия: F, Файл опубликован: 29 июл 2016
Микросхема Преобразователь DA, DAC121S101QML 12Bit Micro Power Digital-to-Analog Converter with Rail-to-Rail Output
DAC121S101WGRQV
223 162 ₽
Элитан
DAC121S101WGRQV
892 307 ₽
DAC121S101WGRQV
DAC121S101WGRQV
Pin1010101010
Package TypeNACNACNACNACNAC
Industry STD TermCFPCFPCFPCFPCFP
JEDEC CodeR-CDFP-GR-CDFP-GR-CDFP-GR-CDFP-GR-CDFP-G
Package QTY5454545454
Маркировка01VZA ACOWGRQMLV QDAC121S1015962R0722601VZA >T
Width (мм)6.1216.1216.1216.1216.121
Length (мм)6.8586.8586.8586.8586.858
Thickness (мм)1.7781.7781.7781.7781.778
Pitch (мм)1.271.271.271.271.27
Max Height (мм)2.342.342.342.342.34
Mechanical DataСкачатьСкачатьСкачатьСкачатьСкачать
АрхитектураString
DAC Channels1
DNL(Max)1 +/-LSB
Gain Error(Max)1 %FSR
INL(Max)8 +/-LSB
InterfaceSPI
Рабочий диапазон температурот -55 до 125,25 C
Output Range Max.5.5 мА
Тип выходаBuffered Voltage
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
Power Consumption(Typ)0.52 mW
RatingSpace
Reference: TypeExt
Разрешение12 Bits
Sample / Update Rate1.8 MSPS
Время установления12.5 µs
RoHSSee ti.com
  • Evaluation Modules & Boards: DAC121S101CVAL
  • AN-2001 Daisy Chaining Precision DACs (Rev. A)
    PDF, 75 Кб, Версия: A, Файл опубликован: 1 май 2013
    It is not uncommon for the system designer to face a quagmire of reconciling the system complexity withthe desire to keep the system footprint small. One specific example that often arises in the context ofsmall system footprint is the need for single master controller to communicate with a number of slavedevices. This is not much of a problem if the master controller has multiple I/O resour
  • Semiconductors > Space & High Reliability > Data Converter > Digital to Analog Converters
На английском языке: Datasheet Texas Instruments DAC121S101WGRQV
