Datasheet Texas Instruments TMS320P15NA — Даташит
СерияTMS320P15
МодельTMS320P15NA
Процессоры цифровых сигналов 40-PDIP от -40 до 85
Datasheet
TSP
Цифровой сигнальный процессор DSP, DSP Fixed-Point 16Bit 20.5MHz 5MIPS 40Pin PDIP
TMS320P15NA
1 231 ₽
TMS320P15NA
1 415 ₽
TMS320P15NA
1 533 ₽
Hi-Tech Circuit Group
TMS320P15NA
Pin40
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)13.71
Length (мм)52.46
Thickness (мм)5.08
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • TMS320C1x Evaluation Module Analog Interface
    PDF, 173 Кб, Файл опубликован: 1 янв 1993
    The TMS320C16 evaluation module (EVM) is used to evaluate the performance characteristics of the TMS320C1x 16-bit fixed-point digital signal processor (DSP). This document builds a supplemental analog interface board that provides the analog capabilities commonly used by the DSP chip. This detailed document includes the schematics, the parts list, the cable connections, the power requirements, and
  • Minimizing Quantization Effects Using the TMS320 DSP Family
    PDF, 268 Кб, Файл опубликован: 1 июл 1994
    Due to its discrete nature DSPs represent variables and performs arithmetic functions with a finite word length. This produces three effects: the selection of filter transfer functions is quantized with filter poles and zeros existing only at specific locations in the z plane; the input is quantized; and noise is introduced from DSP multiplication and division operations. This document shows how
  • Semiconductors > Processors > Other Processors
На английском языке: Datasheet Texas Instruments TMS320P15NA
