Линейка продуктов KEEN SIDE
Datasheet Texas Instruments ADS7816UCG4 — Даташит
СерияADS7816
МодельADS7816UCG4
12-битный высокоскоростной аналого-цифровой преобразователь микромощности с дискретизацией по мощности 8-SOIC от -40 до 85
12-Bit High Speed Micro Power Sampling Analog-To-Digital Converter datasheet
PDF, 975 Кб, Файл опубликован: 27 сен 2000
Pin888
Package TypeDDD
Industry STD TermSOICSOICSOIC
Package QTY757575
CarrierTUBETUBETUBE
МаркировкаADS7816UC
Width (мм)3.913.913.91
Length (мм)4.94.94.9
Thickness (мм)1.581.581.58
Pitch (мм)1.271.271.27
Max Height (мм)1.751.751.75
# Input Channels1
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)4.5 В
АрхитектураSAR
Digital Supply(Max)5.25 В
Digital Supply(Min)4.5 В
INL(Max)2 +/-LSB
Input Range(Max)5.25 В
Тип входаPseudo-Differential,Single-Ended
Integrated FeaturesN/A
InterfaceSerial
Multi-Channel ConfigurationN/A
Power Consumption(Typ)1.9 mW
Reference ModeExt
Разрешение12 Bits
SINAD72 дБ
SNR72 дБ
Sample Rate (max)200kSPS SPS
Sample Rate(Max)0.2 MSPS
THD(Typ)-84 дБ
  • Voltage Reference Scaling Techniques Increase Converter and Resolution Accuracy (Rev. A)
    PDF, 67 Кб, Версия: A, Файл опубликован: 8 май 2015
  • Short Cycling the 8-Pin ADS78xx Family
    PDF, 65 Кб, Файл опубликован: 27 сен 2000
    The most recent 8-pin, 12-bit A/D converters that Burr-Brown has introduced to the market are advertised as high speed, micropower, low priced sampling SAR devices. During product development and the initial introduction period, the engineering effort was placed on optimizing the combination of 12 bits with high speed, low power and low cost. Burr-Brown Applications has revisited these converters
  • Interfacing the ADS7822 to synchronous serial port of the 80x51 Microcontroller
    PDF, 69 Кб, Файл опубликован: 27 сен 2000
    Analog-to-digital converters can be controlled by a normal I/O port or with the synchronous serial port of the 80x51 microcontrollers. The synchronous serial port is more efficient, however, there are some pitfalls to be aware of when configuring the 8-pin A/D converters (ADS1286, ADS7816, ADS7817 and ADS7822) from Burr-Brown. This application bulletin describes how to get around these pitfalls an
  • Coding Schemes Used with Data Converters (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 15 май 2015
  • Interfacing the MSOP8EVM to TMS320C6x Processors
    PDF, 219 Кб, Файл опубликован: 2 дек 2003
    The modular MSOP8EVM is an evaluation module for single-channel, low-power, 8 to 16-bit serial analog-to-digital converters. This application note presents a method for interfacing this EVM to the TMS320C6x Series DSKs using a 5-6K Interface Board. The EVM software provides compile options to choose the proper data formatting for the ADS7816, ADS7817, ADS7818, ADS7822, ADS7826, ADS7829, ADS7835, A
  • Interfacing the MSOP8EVM to TMS320C5x Processors
    PDF, 225 Кб, Файл опубликован: 28 апр 2004
    This application note presents a method for interfacing the modular MSOP8 evaluation module (EVM), an EVM for single-channel, low-power, 8- to 16-bit serial analog-to-digital converters, to the TMS320C5x series DSKs using a 5-6K interface board. The software developed provides compile options to choose the proper data formatting for the ADS7816, ADS7817, ADS7818, ADS7822, ADS7826, ADS7827, ADS7829
  • Interfacing the MSOP8EVM to MSP430 Processors
    PDF, 54 Кб, Файл опубликован: 28 июл 2004
    This application note presents a method for interfacing the modular MSOP8EVM - an EVM for single-channel, low-power, 8- to 16-bit serial analog-to-digital converters - to the MSP430 series microcontrollers. The hardware used for this example includes the HPA449 from SoftBaugh, Inc. (www.softbaugh.com), featuring the MSP430F449. The software developed provides compile options to choose the proper d
  • Interfacing the MSOP8EVM to TMS470 Processors
    PDF, 68 Кб, Файл опубликован: 15 мар 2006
    This application report presents a method for interfacing the modular MSOP8EVM, an evaluation module (EVM) for single-channel, low-power, 8- to 16-bit serial analog-to-digital converters to the TMS470 series microcontrollers. The hardware used for this example includes the TMS470 Kickstart Development Kit evaluation kit featuring the 60-MHz TMS470R1B1M and the HPA-MCU Interface Board. The soft
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
На английском языке: Datasheet Texas Instruments ADS7816UCG4
