Datasheet Texas Instruments TS5A22364DRCR — Даташит
СерияTS5A22364
МодельTS5A22364DRCR
0.65-О© Dual SPDT Analog Switch With Negative Rail Capability 10-VSON -40 to 85
TS5A22364 0.65-О© Dual SPDT Analog Switches With Negative Signaling Capability datasheet
PDF, 1.4 Мб, Версия: H, Файл опубликован: 21 июн 2017
АЦП азиатских производителей
Pin10
Package TypeDRC
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаZVF
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Additional FeaturesBreak-before-make,Supports negative voltages,Click/Pop Noise Reduction
Полоса частот18.3 МГц
Bandwidth(Max)18.3 МГц
Configuration2:1 SPDT
ESD Charged Device Model1.5 kV
ESD HBM2.5 kV
Input/Ouput Voltage(Max)5.5 В
Input/Ouput Voltage(Min)-3.2 В
Input/Output Continuous Current(Max)350 мА
Input/Output ON-state Capacitance(Typ)370 пФ
Количество каналов2
ON-state leakage current(Max)0.375 мкА
Package GroupVSON
Package Size: mm2:W x L10VSON: 9 mm2: 3 x 3(VSON) PKG
Ron(Max)1.3 Ohms
Ron(Typ)0.52 Ohms
Supply Current(Max)5 uA
Supply Current(Typ)0.1 uA
Supply Range5.5 Max
VIH(Min)1.4 В
VIL(Max)0.8 В
Vdd(Max)5.5 В
Vdd(Min)2.3 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5A22364 (4)
На английском языке: Datasheet Texas Instruments TS5A22364DRCR
