Datasheet Texas Instruments DAC3484IRKDR — Даташит
СерияDAC3484
МодельDAC3484IRKDR
Четырехканальный, 16-разрядный, 1,25-GSPS, интерполяционный цифро-аналоговый преобразователь (ЦАП) 1x-16x 88-WQFN-MR от -40 до 85
DAC3484 Quad-Channel, 16-Bit, 1.25 GSPS Digital-to-Analog Converter (DAC) datasheet
PDF, 2.6 Мб, Версия: E, Файл опубликован: 4 ноя 2015
Микросхема Преобразователь DA, 4Channel 16Bit 1.25GSPS Digital-to-Analog Converter 88-WQFN-MR -40℃ to 85℃
DAC3484IRKDR
1 997 ₽
DAC3484IRKDR
МосЧип
DAC3484IRKDR
Hi-Tech Circuit Group
DAC3484IRKDR
Pin88
Package TypeRKD
Industry STD TermWQFN-MR
JEDEC CodeS-PQFP-N
Package QTY2000
МаркировкаDAC3484I
Width (мм)9
Length (мм)9
Thickness (мм).75
Pitch (мм).6
Max Height (мм).8
АрхитектураCurrent Source
DAC Channels4
InterfaceParallel LVDS
Interpolation1x,2x,4x,8x,16x
Package GroupWQFN-MR
Package Size: mm2:W x L88WQFN-MR: 81 mm2: 9 x 9(WQFN-MR) PKG
Power Consumption(Typ)1200 mW
Разрешение16 Bits
SFDR82 дБ
Sample / Update Rate1250 MSPS
  • Evaluation Modules & Boards: DAC3482EVM
    DAC3482 Dual-Channel, 16-Bit, 1.25-GSPS Digital-to-Analog Converter Evaluation Module
  • Evaluation Modules & Boards: DAC34H84EVM
    DAC34H84 Quad-Channel, 16-Bit, 1.25-GSPS Digital-to-Analog Converter Evaluation Module
  • Evaluation Modules & Boards: DAC3484EVM
    DAC3484 Quad-Channel, 16-Bit, 1.25-GSPS Digital-to-Analog Converter Evaluation Module
  • Evaluation Modules & Boards: TSW1406EVM
    Pattern Generator: Data Converter EVMs With 8 LVDS Lanes up to 1.0Gbps
  • Evaluation Modules & Boards: FMC-DAC-ADAPTER
    High Speed DAC to FMC (Xilinx) Header Adapter Card
  • Evaluation Modules & Boards: TSW3084EVM
    Wideband Transmit Signal Chain Evaluation Board and Reference Design
  • Evaluation Modules & Boards: TSW3085EVM
  • Evaluation Modules & Boards: DAC34SH84EVM
    DAC34SH84 Quad-Channel, 16-Bit, 1.5-GSPS Digital-to-Analog Converter Evaluation Module
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • Configuring and Optimizing On-Chip PLL of the DAC348x
    PDF, 420 Кб, Файл опубликован: 26 янв 2012
    DAC348x PLL Consideration and Tradeoffs when using the DAC348x
  • Using DAC348x with Fault Detection and Auto Output Shut-off Feature
    PDF, 162 Кб, Файл опубликован: 21 фев 2013
  • Effects of Clock Spur on High Speed DAC Performance (Rev. A)
    PDF, 828 Кб, Версия: A, Файл опубликован: 18 май 2015
  • DAC348x Device Configuration and Synchronization
    PDF, 317 Кб, Файл опубликован: 18 фев 2013
  • Design Summary Multi-row Quad Flat No-lead (MRQFN)
    PDF, 695 Кб, Файл опубликован: 29 авг 2012
    Design Summary Multi-row Quad Flat No-lead (MRQFN) Design Summary Multi-row Quad Flat No-lead (MRQFN)
  • Effects of Clock Noise on High Speed DAC Performance
    PDF, 674 Кб, Файл опубликован: 8 ноя 2012
  • High Speed Digital-to-Analog Converters Basics (Rev. A)
    PDF, 829 Кб, Версия: A, Файл опубликован: 23 окт 2012
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments DAC3484IRKDR
