Datasheet Texas Instruments UC2706J — Даташит
| Серия | UC2706M |
| Модель | UC2706J |
Высокоскоростные драйверы MOSFET с ограничением тока 16-CDIP от -40 до 85
Dual Output Driver datasheet
PDF, 750 Кб, Версия: A, Файл опубликован: 2 май 2001
Купить UC2706J на РадиоЛоцман.Цены — от 1 989 до 2 445 ₽9 предложений от 9 поставщиков Драйвер FET, Driver 1.5A 2Out High Speed Inv/Non-Inv 16Pin CDIP | |||
| UC2706J Texas Instruments | 2 445 ₽ | ||
| UC2706J Texas Instruments | по запросу | ||
| UC2706J. Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Package QTY | 1 |
| Carrier | TUBE |
| Маркировка | UC2706J |
| Width (мм) | 6.92 |
| Length (мм) | 19.56 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Channel Input Logic | N/A |
| Fall Time | 40 нс |
| Input Threshold | TTL |
| Input VCC(Max) | 40 В |
| Input VCC(Min) | 5 В |
| Количество каналов | 2 |
| Package Group | CDIP |
| Peak Output Current | 1.5 A |
| Power Switch | MOSFET,IGBT |
| Prop Delay | 100 нс |
| Rating | Military |
| Rise Time | 40 нс |
| Special Features | Analog Shutdown with Latch,Inhibit Circuit,Thermal Shutdown |
| RoHS | See ti.com |
- U-118 New Driver ICs Optimize High-Speed Power MOSFET Switching CharacteristicsPDF, 573 Кб, Файл опубликован: 5 сен 1999
The UC3705 family of power drivers is made with a high speed Schottky process to interface between low-level control functions and high-power switching devices particularly power MOSFETs. These devices are also an optimum choice for capacitive line drivers where up to 1.5 amps may be switched in either direction. With both inverting and non-inverting inputs available logic signals of either pola - U-137 Practical Considerations in High Performance MOSFET IGBT and MCT GatePDF, 244 Кб, Файл опубликован: 5 сен 1999
The switch-mode power supply industry's trend towards higher conversion frequencies is justified by the dramatic improvement in obtaining higher power densities. And as these frequencies are pushed towards and beyond one MHz the MOSFET transition periods can become a significant portion of the total switching period. Losses associated with the overlap of switch voltage and current not only degrad
Серия: UC2706M (1)
- UC2706J
- Semiconductors > Power Management > MOSFET and IGBT Gate Drivers > Low-side Driver
