Datasheet Texas Instruments UC39432BDTR — Даташит
СерияUC39432B
МодельUC39432BDTR
Прецизионный регулируемый шунтирующий регулятор 8-SOIC от 0 до 70
Datasheet
TSP
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаUC39432BD39432B
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Approx. Price (US$)2.75 | 1ku
On Board Reference1.3
Operating Supply Current(mA)0.5
Operating Supply(Max)(V)36
Operating Supply(Min)(V)2.2
Output Current(A)0.13
Package Size: mm2:W x L (PKG)8SOIC: 29 mm2: 6 x 4.9(SOIC)
Reference Voltage(V)1.3
Vref tol(%)1
  • DN-52 Adjustable Electronic Load for Low Voltage DC Applications
    PDF, 137 Кб, Файл опубликован: 5 сен 1999
    Testing power supply regulation over a specified output current range is greatly simplified with the use of an adjustable electronic load. Load current can be varied from zero to the full rated value with the twist of a panel-mounted potentiometer or by a digital interface. This design note describes a design using the UC39432 in a self-biased, constant-current adjustable electronic load that is f
Серия: UC39432B (1)
  • UC39432BDTR
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Feedback Signal Generator
На английском языке: Datasheet Texas Instruments UC39432BDTR
