Datasheet Texas Instruments TLC2652I-8DG4 — Даташит
СерияTLC2652
МодельTLC2652I-8DG4
Прецизионный операционный усилитель со стабилизацией прерывателем 8-SOIC
TLC2652, TLC2652A, TLC2652Y Advanced LinCMOS Precision Chopper-Stabilized Op Amp datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 9 фев 2005
7 предложений от 7 поставщиков
Микросхема Буферный усилитель, Op Amp Single GP ±8V/16V 8Pin SOIC Tube
TLC2652I-8DG4
256 ₽
TLC2652I-8DG4
310 ₽
TLC2652I-8DG4
390 ₽
TLC2652I-8DG4
Package TypeD
Package QTY75
Маркировка2652I
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Additional FeaturesZero Drift
АрхитектураCMOS
CMRR(Min)120 дБ
CMRR(Typ)140 дБ
GBW(Typ)1.9 МГц
Input Bias Current(Max)60 pA
Iq per channel(Max)2.4 мА
Iq per channel(Typ)1.5 мА
Количество каналов1
Offset Drift(Typ)0.01 uV/C
Output Current(Typ)3 мА
Rail-to-RailIn to V-,Out
Slew Rate(Typ)2.8 V/us
Total Supply Voltage(Min)3.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)23 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.003 мВ
  • AB-174: Getting the Full Potential from your ADC (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 28 июн 2002
    Many of today?s high-resolution ADCs (Analog-to-Digital Converters) are operating from a single supply and use fully differential inputs. This can be a problem for single-ended signals that are bipolar relative to common. This article illustrates circuit configurations that preserve the full-scale input range by using modern features, such as Programmable Gain Amplifiers (PGAs) and internal voltag
  • Choosing an ADC and Op Amp for Minimum Offset
    PDF, 72 Кб, Файл опубликован: 28 окт 1999
    Designing a mixed-signal circuit containing analog and digital components can be a challenge to the development engineer. Requirements such as a low single-polarity supply voltage and a high degree of precision may conflict, and make the choice of components and the best circuit design difficult. This report discusses problems that arise in using operational amplifiers (op amps) for signal conditi
TLC2652I8DG4, TLC2652I 8DG4
На английском языке: Datasheet Texas Instruments TLC2652I-8DG4
