Datasheet Texas Instruments TMS320C5505AZCHA10 — Даташит
СерияTMS320C5505
МодельTMS320C5505AZCHA10
Процессор цифровых сигналов с фиксированной точкой 196-NFBGA от -40 до 85
TMS320C5505 Fixed-Point Digital Signal Processor datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 13 авг 2013
Pin196
Package TypeZCH
Industry STD TermNFBGA
JEDEC CodeS-PBGA-N
Package QTY184
CarrierJEDEC TRAY (5+1)
Маркировка05AZCHA10
Width (мм)10
Length (мм)10
Thickness (мм).89
Max Height (мм)1.3
ApplicationsCommunications and Telecom,Industrial,Medical
DRAMSDRAM,mSDRAM
DSP1 C55x
DSP MHz100,120,150 Max.
I2C1
Operating SystemsDSP/BIOS,VLX
Рабочий диапазон температурот -10 до 70,-40 до 85 C
Other Hardware AccelerationFFT Coprocessor
SPI1
UART1 SCI
USB1
    XDS200 USB Debug Probe
  • Evaluation Modules & Boards: TMDX5505EZDSP
    C5505 eZdspВ™ USB Stick Development Tool
  • Evaluation Modules & Boards: TMDX5515EZDSP
    C5515 eZDSP USB Stick Development Tool
  • Development Kits: TMDXEVM5515
    TMS320C5515 DSP Evaluation Module
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
  • FFT Implementation on the TMS320VC5505, TMS320C5505, and TMS320C5515 DSPs (Rev. B)
    PDF, 392 Кб, Версия: B, Файл опубликован: 9 янв 2013
    The Fast Fourier Transform (FFT) is an efficient means for computing the Discrete Fourier Transform (DFT). It is one of the most widely used computational elements in Digital Signal Processing (DSP) applications. This DSP is ideally suited for such applications. They include an FFT hardware accelerator (HWAFFT) that is tightly coupled with the CPU, allowing high FFT processing performance at very
  • Using the TMS320C5515/14/05/04 Bootloader (Rev. C)
    PDF, 1.8 Мб, Версия: C, Файл опубликован: 15 июл 2015
  • Instructions to Benchmark C55 DSP Library
    PDF, 3.2 Мб, Файл опубликован: 1 апр 2016
    DSP Library (DSPLIB) is a collection of optimized C55x assembly functions that implement a wide variety of DSP functions. The TMS320C55x DSP Library Programmer’s Reference User's Guide provides cycle estimation for the execution of each function in the library. This work enables the user to measure the performances of a sub-set of the DSPLIB functions executed on real hardware, and with some addit
  • Migrating from TMS320C5515/05 to TMS320C5535/34/33/32 (Rev. A)
    PDF, 352 Кб, Версия: A, Файл опубликован: 22 дек 2011
    This document provides the minimum changes required to migrate from TMS320C5515/05 to TMS320C5535/34/33/32. Enhancements or new features of the TMS320C5535/34/33/32 devices that do not affect migrating from the TMS320C5515/05 devices will also be briefly mentioned in this document.All efforts have been made to provide a comprehensive list of changes. An update will be provided if additional c
  • C5000 DSP-Based Low-Power System Design
    PDF, 169 Кб, Файл опубликован: 30 ноя 2015
    Low-power consumption is one of the most important requirements for the embedded system. The C5000в„ў ultra low-power DSP family is ideal for portable devices (audio, voice and vision) and other applications that require analytics with low power.To take advantage of this feature in system design, good practices need to be carried out. This application report focuses on the Texas Instrum
  • Power Estimation and Pwr Consumption Sum for TMS320C5504/05/14/15/32/33/34/35/45 (Rev. A)
    PDF, 555 Кб, Версия: A, Файл опубликован: 4 апр 2016
    This application report assists in estimating the power consumption for the TMS320C5515, C5504, C5505, C5514, C5532, C5533, C5534, C5535 and C5545 devices (DSPs), using a power estimation spreadsheet.
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > C55x DSP
На английском языке: Datasheet Texas Instruments TMS320C5505AZCHA10
