Datasheet Texas Instruments BQ24123RHLR — Даташит
СерияBQ24123
МодельBQ24123RHLR
Синхронное импульсное 2-элементное литий-ионное зарядное устройство с полевым транзистором 2 А, улучшенными характеристиками электромагнитных помех 20-VQFN от -40 до 85
bq2412x Single-Chip Switched-Mode, Li-Ion, and Li-Polymer Charge-Management IC With Enhanced EMI Performance (bqSWITCHERв„ў) datasheet
PDF, 2.1 Мб, Версия: H, Файл опубликован: 30 ноя 2015
Pin20
Package TypeRHL
Industry STD TermVQFN
JEDEC CodeR-PQFP-N
Package QTY3000
МаркировкаBQV
Width (мм)3.5
Length (мм)4.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Absolute Vin (safety rating)(Max)(20 В
Battery Charge Voltage(Max)4.2,8.4 В
Battery Charge Voltage(Min)4.2,8.4 В
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)2 A
Control InterfaceStandalone (RC-Settable)
Control TopologySwitch-Mode Buck
Number of Series Cells1,2,3
Operating Vin(Max)16 В
Operating Vin(Min)4.35 В
Package GroupVQFN
Package Size: mm2:W x L20VQFN: 16 mm2: 3.5 x 4.5(VQFN) PKG
Special FeaturesIntegrated FET,Temp Monitoring (Thermistor Pin)
USB FeatureN/A
  • Evaluation Modules & Boards: BQ24123EVM-002
    bq24123 Evaluation Module
  • bq24103/13/23/33 Comparison
    PDF, 38 Кб, Файл опубликован: 12 авг 2011
    This application report presents an overview of the differences among the bq24103, bq24113, bq24123 and bq24133. It assists design engineers in selecting the most suitable charger for their applications.
  • Implementations of Battery Charger and Power-Path Mgmt System Using bq241xx
    PDF, 752 Кб, Файл опубликован: 6 июн 2006
    This application report presents four system topologies that can be used to fully implement a portable power management system solution using the bqSWITCHERв„ў. Test results and the advantages and issues of each topology are discussed.
  • Drive High Current LEDs
    PDF, 437 Кб, Файл опубликован: 25 янв 2007
    This application report presents high-current LED driving requirements that use the TI integrated boost converter IC TPS6106x and integrated buck converter IC bqSWITCHERв„ў (bq2410x/11x/12x). Step-by-step design procedures, measurement results, and two dimming methods are provided and discussed.
Серия: BQ24123 (4)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24123RHLR
