Datasheet ТI TPS61020DRCR — Даташит
| Серия | TPS61020 |
| Модель | TPS61020DRCR |
Регулируемый переключатель на 1,5 А, повышающий преобразователь с КПД 96 % и режимом понижения, QFN-10 10-VSON от -40 до 85
TPS6102x 96% Efficient Synchronous Boost Converter datasheet
PDF, 1.2 Мб, Версия: G, Файл опубликован: 24 дек 2014
- TPS61020 Boost Converter Start-Up and PrechargePDF, 488 Кб, Файл опубликован: 28 янв 2010
The TPS61020 is a highly integrated, low-power, boost converter ideally suited for portable battery-powered equipment. To improve start-up performance from a power-limited source such as a battery, the TPS6102x family uses different steps and modes to reduce demand on the battery. This prevents the battery bus from sagging during start-up and improves start-up operation at low voltage. - Factors That Determine Light Load PSM Switch Freq for TPS6102x Boost ConvertersPDF, 528 Кб, Файл опубликован: 21 апр 2006
- TPS6102x Boost Converter Down Conversion ModePDF, 159 Кб, Файл опубликован: 16 дек 2004
The TPS61020 is a highly integrated, low-power, boost converter ideally suited for portable battery-powered equipment. The integrated down conversion mode allows the boost converter to operate with the input voltage greater than the output voltage, which is normally only possible with more complicated converters. - Calculating and Measuring the No Load Input Current of the Boost ConverterPDF, 143 Кб, Файл опубликован: 23 сен 2016
- Five Steps to a Good PCB Layout of the Boost ConverterPDF, 701 Кб, Файл опубликован: 3 май 2016
- Minimizing Ringing at the Switch Node of a Boost ConverterPDF, 201 Кб, Файл опубликован: 15 сен 2006
The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter. - Design considerations for a resistive feedback divider in a DC/DC converterPDF, 393 Кб, Файл опубликован: 26 апр 2012
- Basic Calculation of a Boost Converter's Power Stage (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed. - Optimizing Transient Response of Internally Compensated DC-DC Converters (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 11 май 2015
- Extending the Soft Start Time Without a Soft Start Pin (Rev. B)PDF, 387 Кб, Версия: B, Файл опубликован: 15 июн 2017
- Choosing an Appropriate Pull-up/Pull-down Resistor for Open Drain OutputsPDF, 130 Кб, Файл опубликован: 19 сен 2011
- QFN and SON PCB Attachment (Rev. B)PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
- IQ: What it is what it isn’t and how to use itPDF, 198 Кб, Файл опубликован: 17 июн 2011
- Performing Accurate PFM Mode Efficiency Measurements (Rev. A)PDF, 418 Кб, Версия: A, Файл опубликован: 11 дек 2018
Серия: TPS61020 (2)
- TPS61020DRCR TPS61020DRCRG4
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
