Datasheet Texas Instruments 74ACT16244DGGRE4 — Даташит
| Серия | 74ACT16244 |
| Модель | 74ACT16244DGGRE4 |
16-битные буферы/драйверы линий с выходами с 3 состояниями 48-TSSOP от -40 до 85
SN54ACT16244, 74ACT16244 datasheet
PDF, 747 Кб, Версия: B, Файл опубликован: 1 апр 1996
Купить 74ACT16244DGGRE4 на РадиоЛоцман.Цены — от 51 до 65 ₽9 предложений от 9 поставщиков Микросхема Логический контроллер, 16Bit Buffers/Line Drivers With 3-State Outputs 48-TSSOP -40℃ to 85℃ | |||
| 74ACT16244DGGRE4 Texas Instruments | 64 ₽ | ||
| 74ACT16244DGGRE4 Texas Instruments | 65 ₽ | ||
| 74ACT16244DGGRE4 Texas Instruments | по запросу | ||
| 74ACT16244DGGRE4 | по запросу | ||
| Pin | 48 |
| Package Type | DGG |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | ACT16244 |
| Width (мм) | 6.1 |
| Length (мм) | 12.5 |
| Thickness (мм) | 1.15 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 16 |
| F @ Nom Voltage(Max) | 90 Mhz |
| ICC @ Nom Voltage(Max) | 0.08 мА |
| Output Drive (IOL/IOH)(Max) | -24/24 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | ACT |
| VCC(Max) | 5.5 В |
| VCC(Min) | 4.5 В |
| Voltage(Nom) | 5 В |
| tpd @ Nom Voltage(Max) | 9.5 нс |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - TI IBIS File Creation Validation and Distribution ProcessesPDF, 380 Кб, Файл опубликован: 29 авг 2002
The Input/Output Buffer Information Specification (IBIS) also known as ANSI/EIA-656 has become widely accepted among electronic design automation (EDA) vendors semiconductor vendors and system designers as the format for digital electrical interface data. Because IBIS models do not reveal proprietary internal processes or architectural information semiconductor vendors? support for IBIS con - Understanding and Interpreting Standard-Logic Data Sheets (Rev. C)PDF, 614 Кб, Версия: C, Файл опубликован: 2 дек 2015
- Semiconductor Packing Material Electrostatic Discharge (ESD) ProtectionPDF, 337 Кб, Файл опубликован: 8 июл 2004
Forty-eight-pin TSSOP components that were packaged using Texas Instruments (TI) standard packing methodology were subjected to electrical discharges between 0.5 and 20 kV as generated by an IEC ESD simulator to determine the level of ISD protection provided by the packing materials. The testing included trays tape and reel and magazines. Additional units were subjected to the same discharge - Introduction to LogicPDF, 93 Кб, Файл опубликован: 30 апр 2015
- Implications of Slow or Floating CMOS Inputs (Rev. D)PDF, 260 Кб, Версия: D, Файл опубликован: 23 июн 2016
- CMOS Power Consumption and CPD Calculation (Rev. B)PDF, 89 Кб, Версия: B, Файл опубликован: 1 июн 1997
Reduction of power consumption makes a device more reliable. The need for devices that consume a minimum amount of power was a major driving force behind the development of CMOS technologies. As a result CMOS devices are best known for low power consumption. However for minimizing the power requirements of a board or a system simply knowing that CMOS devices may use less power than equivale - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: 74ACT16244 (7)
- 74ACT16244DGGR 74ACT16244DGGRE4 74ACT16244DGGRG4 74ACT16244DL 74ACT16244DLG4 74ACT16244DLR 74ACT16244DLRG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
