Datasheet Texas Instruments ADS901E — Даташит
СерияADS901
МодельADS901E
10-битный аналого-цифровой преобразователь (АЦП) с быстродействием 20 MSPS 28-SSOP от -40 до 85
ADS901: SpeedPlus? 10-Bit, 20MHz, +3V Supply Analog-To-Digital Converter datasheet
PDF, 254 Кб, Версия: A, Файл опубликован: 23 фев 2001
32 предложений от 25 поставщиков
Микросхема Преобразователь AD, 10Bit, 20MSPS Analog-to-Digital Converter (ADC) 28-SSOP -40℃ to 85℃
ADS901E
441 ₽
Рутоника
ADS901E
554 ₽
ADS901E
1 813 ₽
SUV System
ADS901E/1K
Pin28
Package TypeDB
Industry STD TermSSOP
Package QTY50
МаркировкаADS901E
Width (мм)5.3
Length (мм)10.2
Thickness (мм)1.95
Max Height (мм)2
# Input Channels1
Analog Input BW100 МГц
АрхитектураPipeline
DNL(Max)1 +/-LSB
DNL(Typ)0.8 +/-LSB
ENOB8 Bits
INL(Max)3.5 +/-LSB
INL(Typ)3.5 +/-LSB
Input BufferNo
Input Range1,2 Vp-p
InterfaceParallel CMOS
Package GroupSSOP
Package Size: mm2:W x L28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG
Power Consumption(Typ)49 mW
Reference ModeExt
Разрешение10 Bits
SFDR49 дБ
SINAD50 дБ
SNR53 дБ
Sample Rate(Max)20 MSPS
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • CDCE62005 as Clock Solution for High-Speed ADCs
    PDF, 805 Кб, Файл опубликован: 4 сен 2008
    TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527 which is capable of sampling up to 210 MSPS. To realize the full potential of these high-performance products it is imperative to provide a low phase noise clock source. The CDCE62005 clock synthesizer chip offers a real-world clocking solution to meet these stringent requirements
  • Smart Selection of ADC/DAC Enables Better Design of Software-Defined Radio
    PDF, 376 Кб, Файл опубликован: 28 апр 2009
    This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs and the DAC5688 from Texas Instruments fit properly for SDR designs.
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
Серия: ADS901 (1)
  • ADS901E
  • Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
На английском языке: Datasheet Texas Instruments ADS901E
