Datasheet Texas Instruments BQ2000TSN-B5G4 — Даташит
СерияBQ2000T
МодельBQ2000TSN-B5G4
Импульсное многохимическое зарядное устройство с оконечной нагрузкой dT/dt 8-SOIC от -20 до 70
Programmable Multi-Chemistry Fast-Charge Management IC* datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 14 янв 2010
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
# Series Cells1
2
3
4
Absolute Vin (safety rating)(Max)((V))7
Approx. Price (US$)1.84 | 1ku
Battery Charge Voltage(Max)(V)20
Cell ChemistryLi-Ion/Li-Polymer
NiCd
NiMH
Charge Current(Max)(A)2
Control InterfaceStandalone (RC-Settable)
Control TopologySwitch-Mode Buck
Operating Vin(Max)(V)6
Operating Vin(Min)(V)4
Special FeaturesTemp Monitoring (Thermistor Pin)
USB FeatureN/A
RoHSНе совместим
  • Evaluation Modules & Boards: BQ2000EVM
    Evaluation Module for Battery Charge Management IC
  • Battery Charger Termination Issues With System Load Applied Across Battery (Rev. A)
    PDF, 151 Кб, Версия: A, Файл опубликован: 2 окт 2006
    Battery Charger Termination Issues With System Load Applied Across Battery While Charging
  • U-504 Using the bq2000/T to Control Fast Charge (Rev. B)
    PDF, 193 Кб, Версия: B, Файл опубликован: 2 дек 2004
    The bq2000/T are programmable, monolithic ICs for fast-charge management of nickel cadmium, nickel metal-hydride, and lithium-ion batteries in single- or multichemistry applications. This application note discusses simple ways to select all necessary components to implement various switch-mode topologies. It also discusses how to configure the bq2000/T inputs to accomodate different appplication c
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
BQ2000TSNB5G4, BQ2000TSN B5G4
На английском языке: Datasheet Texas Instruments BQ2000TSN-B5G4
