Datasheet Texas Instruments SN74LVT32244ZKER — Даташит
СерияSN74LVT32244
МодельSN74LVT32244ZKER
3,3 В ABT, 32-битный буфер/драйвер с выходами с 3 состояниями 96-LFBGA от -40 до 85
SN74LVT32244 datasheet
PDF, 779 Кб, Версия: C, Файл опубликован: 1 ноя 2006
Pin96
Package TypeZKE
Industry STD TermBGA MICROSTAR
JEDEC CodeR-PBGA-N
Package QTY1000
МаркировкаVJ244
Width (мм)5.5
Length (мм)13.5
Thickness (мм).85
Pitch (мм).8
Max Height (мм)1.4
Bits32
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-32/64 мА
Package GroupLFBGA
Package Size: mm2:W x L96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA) PKG
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)3.2 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVT32244 (2)
На английском языке: Datasheet Texas Instruments SN74LVT32244ZKER
