Datasheet Texas Instruments SN74AUC14RGYRG4 — Даташит
СерияSN74AUC14
МодельSN74AUC14RGYRG4
ИНВЕРТОР ШЕСТИГРАННОГО ТРИГГЕРА ШМИТТА 14-VQFN от -40 до 85
SN74AUC14 Hex Schmitt-Trigger Inverter datasheet
PDF, 781 Кб, Версия: A, Файл опубликован: 7 май 2010
Pin14
Package TypeRGY
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаMS14
Width (мм)3.5
Length (мм)3.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Bits6
F @ Nom Voltage(Max)250 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-9/9 мА
Package GroupVQFN
Package Size: mm2:W x L14VQFN: 12 mm2: 3.5 x 3.5(VQFN) PKG
Schmitt TriggerYes
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)1.8,2.5 В
tpd @ Nom Voltage(Max)3.5,2.7 нс
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Understanding Schmitt Triggers
    PDF, 80 Кб, Файл опубликован: 21 сен 2011
Серия: SN74AUC14 (2)
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74AUC14RGYRG4
