Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LMH6551MM/NOPB — Даташит
СерияLMH6551
МодельLMH6551MM/NOPB
Дифференциальный высокоскоростной операционный усилитель 8-VSSOP от -40 до 85
LMH6551 Differential, High-Speed Op Amp datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 19 янв 2015
Package TypeDGK
Industry STD TermVSSOP
Package QTY1000
МаркировкаAU1A
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
2nd Harmonic94 dBc
3rd Harmonic96 dBc
@ MHz5
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Fully Differential,Voltage FB
BW @ Acl370 МГц
CMRR(Min)72 дБ
CMRR(Typ)80 дБ
GBW(Typ)370 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)14.5 мА
Iq per channel(Typ)12.5 мА
Количество каналов1
Offset Drift(Typ)0.8 uV/C
Output Current(Typ)65 мА
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Rail-to-RailNo
Slew Rate(Typ)2400 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)3 +5V=5, +/-5V=10
Vn at 1kHz(Typ)6 нВ/rtГц
Vn at Flatband(Typ)6 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • Evaluation Modules & Boards: LMH730154
    Evaluation Board for High-Speed Single Differential Amplifier in the 8-Pin SOIC Package
  • A Walk Along the Signal Path (High-Speed Signal Path)
    PDF, 461 Кб, Файл опубликован: 30 мар 2005
  • Using High Speed Diff Amp to Drive ADCs (Rev. A)
    PDF, 175 Кб, Версия: A, Файл опубликован: 26 апр 2013
    The right high speed differential amplifier will add flexibility to signal chains that include a high speedanalog-to-digital converter (ADC). A differential amplifier can provide signal conditioning such as singleended to differential conversion, impedance transformation, and gain or attenuation.
  • AN-1719 Noise Figure Analysis Fully Differential Amplifier (Rev. A)
    PDF, 97 Кб, Версия: A, Файл опубликован: 1 май 2013
    This application note provides noise figure analysis for fully differential amplifiers, including output noisecalculation and noise figure calculation.
  • Understanding High-Speed Signals, Clocks, and Data Capture
    PDF, 1.9 Мб, Файл опубликован: 18 окт 2005
  • Converting single-ended video to differential video in single-supply systems
    PDF, 212 Кб, Файл опубликован: 16 сен 2011
На английском языке: Datasheet Texas Instruments LMH6551MM/NOPB
