Datasheet Texas Instruments TS5A21366DCURG4 — Даташит
СерияTS5A21366
МодельTS5A21366DCURG4
Аналоговый переключатель с двойным SPST, сопротивлением 0,75 Ом и входной логикой, совместимой с напряжением 1,8 В, 8-VSSOP
TS5A21366 0.75-О© 2-channel SPST Analog Switch With 1.8-V Compatible Input Logic datasheet
PDF, 1.4 Мб, Версия: B, Файл опубликован: 25 авг 2016
Package TypeDCU
Industry STD TermVSSOP
МаркировкаJBSR
Width (мм)2
Length (мм)2.3
Thickness (мм).85
Pitch (мм).5
Max Height (мм).9
Additional FeaturesLow Harmonic Distortion
Low Power
Approx. Price (US$)0.41 | 1ku
Bandwidth(MHz)260
Bandwidth(Max)(MHz)260
Charge Injection(Max)(pC)1.4
Configuration1:1 SPST
Crosstalk(dB)-101
Digital input leakage(Max)(uA)0.6
ESD Charged Device Model(kV)1
ESD HBM(kV)2
ICC(Max)(uA)10
Input/Ouput Voltage(Max)(V)5.5
Input/Output Continuous Current(Max)(mA)400
Input/Output OFF-state Capacitance(Typ)(pF)17
Input/Output ON-state Capacitance(Typ)(pF)27.5
Mux Configuration1:1
Number of Channels(#)2
OFF-state leakage current(Max)(ВµA)10
ON-state leakage current(Max)(ВµA)0.05
Off Isolation(Typ)(dB)-59
Operating Temperature Range(C)-40 to 85
Package GroupVSSOP
Package Size: mm2:W x L (PKG)8VSSOP: 6 mm2: 3.1 x 2(VSSOP)
RON Flatness(Max)(Ohms)3
Ron Channel Match(Max)(Ω)0.2
Ron(Max)(Ohms)5
Ron(Typ)(Ohms)1.6
THD(Typ)(%)0.001
THD(Typ)(dB)-100
Turn off Time (Disable)(ns)514
Turn on Time (Enable)(Max)(ns)620
VCC(Max)(V)5.5
VCC(Min)(V)1.65
VIH(Min)(V)1.05
VIL(Max)(V)0.6
RoHSНе совместим
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5A21366 (3)
  • Semiconductors > Switches and Multiplexers > Signal Switches > Analog Switch
На английском языке: Datasheet Texas Instruments TS5A21366DCURG4
