Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74LVC1G332DRYR — Даташит
СерияSN74LVC1G332
МодельSN74LVC1G332DRYR
Одиночный вентиль положительного ИЛИ с 3 входами 6-SON от -40 до 125
SN74LVC1G332 datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 11 янв 2012
Pin6
Package TypeDRY
Industry STD TermUSON
JEDEC CodeR-PDSO-N
Package QTY5000
МаркировкаCZ
Width (мм)1
Length (мм)1.45
Thickness (мм).5
Pitch (мм).5
Max Height (мм).6
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeOR
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSON
Package Size: mm2:W x LSee datasheet (SON) PKG
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,low power
Sub-FamilyOR Gate
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)17.2,6.2,4.8,3.5 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G332DRYR
