Datasheet Texas Instruments LMS8117AMP-1.8/NOPB — Даташит
СерияLMS8117A
МодельLMS8117AMP-1.8/NOPB
Линейный регулятор с фиксированным/регулируемым выходом 1 А/LDO 4-SOT-223 от 0 до 125
LMS8117A 1-A Low-Dropout Linear Regulator datasheet
PDF, 651 Кб, Версия: F, Файл опубликован: 16 дек 2016
34 предложений от 19 поставщиков
Чип стабилизации напряжения, TEXAS INSTRUMENTS LMS8117AMP-1.8/NOPB Fixed LDO Voltage Regulator, 2.5V to 15V, 1.2V Dropout, 1.8Vout, 1Aout, SOT-223-3
LMS8117AMP-1.8/NOPB
56 ₽
LMS8117AMP-1.8/NOPB
от 169 ₽
727GS
LMS8117AMP-1.8/NOPB
214 ₽
SUV System
LMS8117AMP-1.8/NOPB
Pin4
Package TypeDCY
Industry STD TermSOT-223
Package QTY1000
МаркировкаLS00
Width (мм)3.5
Length (мм)6.5
Thickness (мм)1.6
Pitch (мм)2.3
Max Height (мм)1.8
Точность3 %
Fixed Output Options1.8,3.3 В
Iout(Max)1 A
Iq(Typ)5 мА
Рабочий диапазон температурот 0 до 125 C
PSRR @ 100KHz37 дБ
Package GroupSOT-223
Package Size: mm2:W x L4SOT-223: 46 mm2: 7 x 6.5(SOT-223) PKG
Regulated Outputs1
Special FeaturesN/A
Thermal Resistance ОёJA56 В°C/W
Vdo(Typ)1200 мВ
Vin(Max)15 В
Vin(Min)2.5 В
Vout(Max)13.75 В
Vout(Min)1.5 В
  • Method For Cal Output Voltage Tolerances in Adj Regs (Rev. A)
    PDF, 284 Кб, Версия: A, Файл опубликован: 5 май 2013
    When working with voltage regulator circuits the designer is often confronted with the need to calculatethe tolerance of the regulated output voltage. For fixed voltage regulators this problem is easily managedbecause the required information is directly supplied on the semiconductor manufacturer's data sheet.
  • AN-1482 LDO Regulator Stability Using Ceramic Output Capacitors (Rev. A)
    PDF, 169 Кб, Версия: A, Файл опубликован: 25 апр 2013
    Ultra-low ESR capacitors such as ceramics are highly desirable because they can support fast-changingload transients and also bypass very high frequency noise coming from switching converter powersources which a linear regulator can not reject. However using ultra-low ESR capacitors on the output ofan LDO regulator requires that specific design changes be implemented to ensure loop stabili
LMS8117AMP1.8/NOPB, LMS8117AMP 1.8/NOPB
На английском языке: Datasheet Texas Instruments LMS8117AMP-1.8/NOPB
