Datasheet Texas Instruments THS3096D — Даташит
СерияTHS3096
МодельTHS3096D
Двойной операционный усилитель высокого напряжения с низкими искажениями и токовой обратной связью с 14-SOIC при понижении мощности от -40 до 85
High-Voltage, Low-Distortion, Current-Feedback Operational Amplifier datasheet
PDF, 2.4 Мб, Версия: B, Файл опубликован: 26 янв 2006
Pin14
Package TypeD
Package QTY50
МаркировкаTHS3096
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic66 dBc
3rd Harmonic76 dBc
@ MHz10
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураBipolar,Current FB
BW @ Acl145 МГц
CMRR(Min)68 дБ
CMRR(Typ)78 дБ
GBW(Typ)145 МГц
Input Bias Current(Max)15000000 pA
Iq per channel(Max)10.5 мА
Iq per channel(Typ)9.5 мА
Количество каналов2
Offset Drift(Typ)10 uV/C
Output Current(Typ)250 мА
Rail-to-RailNo
Slew Rate(Typ)5700 V/us
Total Supply Voltage(Max)30 +5V=5, +/-5V=10
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)2 нВ/rtГц
Vn at Flatband(Typ)2 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)3 мВ
  • Evaluation Modules & Boards: THS3096EVM
    THS3096 Evaluation Module
  • Evaluation Modules & Boards: THS3092EVM
    THS3092 Evaluation Module
  • Design for a Wideband Differential Transimpedance DAC Output (Rev. A)
    PDF, 438 Кб, Версия: A, Файл опубликован: 17 окт 2016
    High-speed digital-to-analog converters commonly offer a complementary current output signal. Most output interface implementations use either a resistive load and/or a transformer to convert this current source signal to a voltage. Where a dc-coupled interface is required, a carefully designed differential transimpedance stage can offer an attractive alternative. Design considerations and options
  • Voltage Feedback vs. Current Feedback Op Amps
    PDF, 93 Кб, Файл опубликован: 30 ноя 1998
    This application report contrasts and compares the characteristics and capabilities of voltage and current feedback operational amplifiers. The report also points out the many similarities between the two versions.
  • Stabilizing Current-Feedback Op Amps While Optimizing Circuit Performance
    PDF, 280 Кб, Файл опубликован: 28 апр 2004
    Optimizing a circuit design with a current-feedback (CFB) op amp is a relatively straightforward task, once one understands how CFB op amps achieve stability. This application note explains a 2nd-order CFB model so that any designer can better understand the flexibility of the CFB op amp. This report also discusses stability analysis, the effects of parasitic components due to PCBs, optimization
  • Designing for low distortion with high-speed op amps
    PDF, 277 Кб, Файл опубликован: 2 мар 2005
Серия: THS3096 (2)
На английском языке: Datasheet Texas Instruments THS3096D
