Datasheet Texas Instruments TLC6C5712QPWPRQ1 — Даташит
СерияTLC6C5712-Q1
МодельTLC6C5712QPWPRQ1
12-битный светодиодный драйвер постоянного тока с приемником 28-HTSSOP от -40 до 125
TLC6C5712-Q1 12-Channel, Full-Diagnostic, Constant-Current-Sink LED Driver With 8-Bit Dot Correction datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 31 авг 2015
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
Маркировка6C5712
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
ApplicationsBacklight,Tell-Tale
Количество каналов12
Iout(Max)0.9 A
Iq(Typ)3.5 мА
LED Current Per Channel75 мА
Package GroupHTSSOP
Package Size: mm2:W x L28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG
RatingAutomotive
Special FeaturesAdjacent-Pin Short Detection,LED Open Detection,LED Short to Ground Detection,LED Weak Supply Diagnostics,SPI Register Lock for Content Protection,Thermal Prewarning and Shutdown
TopologyCurrent Sink
Vin(Max)5.5 В
Vin(Min)3 В
Vout(Max)7 В
  • Evaluation Modules & Boards: TLC6C5712EVM
    TLC6C5712 12 Channels Linear Constant Current LED Driver Evaluation Module
  • TLC6C5712-Q1 Applications Reference Guide
    PDF, 171 Кб, Файл опубликован: 11 авг 2016
    The TLC6C5712-Q1 device is an advanced constant-current LED driver with full LED diagnostics. This report provides a guide on how to use the TLC6C5712-Q1 device on both hardware configuration and software configuration.This report introduces the TLC6C5712-Q1 features and application configurations. It also discusses a software guide on how to realize TLC6C5712-Q1 diagnostics. The report p
Серия: TLC6C5712-Q1 (1)
  • TLC6C5712QPWPRQ1
  • Semiconductors > Power Management > LED Driver > Automotive LED Driver
На английском языке: Datasheet Texas Instruments TLC6C5712QPWPRQ1
