Datasheet Texas Instruments LMV981TL/NOPB — Даташит
Серия | LMV981-N |
Модель | LMV981TL/NOPB |
Одиночные 1,8 В операционные усилители RRIO с отключением 6-DSBGA от -40 до 125
LMV98x-N Small, Low-Power, 1.8-V RRIO Operational Amplifiers With Shutdown datasheet
PDF, 1.6 Мб, Версия: M, Файл опубликован: 30 сен 2016
Pin | 6 | 6 |
Package Type | YZR | YZR |
Industry STD Term | DSBGA | DSBGA |
JEDEC Code | R-XBGA-N | R-XBGA-N |
Package QTY | 250 | 250 |
Carrier | SMALL T&R | SMALL T&R |
Маркировка | H | A |
Width (мм) | 1.3 | 1.3 |
Length (мм) | 1.5 | 1.5 |
Thickness (мм) | .675 | .675 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | .675 | .675 |
Additional Features | Shutdown |
Архитектура | Bipolar |
CMRR(Min) | 60 дБ |
CMRR(Typ) | 86 дБ |
GBW(Typ) | 1.5 МГц |
Input Bias Current(Max) | 35000 pA |
Iq per channel(Max) | 0.23 мА |
Iq per channel(Typ) | 0.116 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 5.5 uV/C |
Output Current(Typ) | 65 мА |
Package Group | DSBGA |
Package Size: mm2:W x L | See datasheet (DSBGA) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 0.42 V/us |
Total Supply Voltage(Max) | 5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 1.8 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 50 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 4 мВ |
- AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or - AN-1684 Saving Power in an AC-Coupled Amplifier Circuit (Rev. A)PDF, 99 Кб, Версия: A, Файл опубликован: 26 апр 2013
AC-coupled circuits are often used for single supply operation to bring the input voltage into the inputrange of the amplifier. This circuit topology can be used in AC smoke detectors or in AC proximitysensors.
Серия: LMV981-N (8)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > General-Purpose Op Amps
