Datasheet Texas Instruments TXS0101DCKR — Даташит
СерияTXS0101
МодельTXS0101DCKR
1-битный двунаправленный преобразователь уровня напряжения для приложений с открытым стоком и двухтактной схемы 6-SC70 от -40 до 85
TXS0101 1-Bit Bidirectional Level-Shifting, Voltage-Level Translator With Auto-Direction-Sensing for Open-Drain and Push-Pull Applications datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 22 июн 2017
Pin6
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
Маркировка2GO
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
3-State OutputNo
Bits1
F @ Nom Voltage(Max)12 Mhz
Gate TypeN/A
ICC @ Nom Voltage(Max)0.012 мА
LogicTrue
Рабочий диапазон температурот -40 до 85,-55 до 125 C
Output Drive (IOL/IOH)(Max)1/-.02 мА
Package GroupSC70
Package Size: mm2:W x L6SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesOne-Shot Edge Accelerators,Bidirectional
Sub-FamilyDual Supply Translator
Technology FamilyTXS
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4.2 нс
  • Development Kits: DLPLIGHTCRAFTER
    DLPВ® LightCrafterВ™ Evaluation Module
  • Effects of pullup and pulldown resistors on TXS and TXB devices
    PDF, 732 Кб, Файл опубликован: 20 сен 2017
    The TXS and TXB family of devices belong to the auto-bidirectional translation products from TI. These devices can be sensitive to external pullup or pulldown resistors due to the internal pullup resistors present in the TXS device and the internal serial resistors present in the TXB device. In this application note, the effects of external pullup and pulldown resistors on VOL and VOH levels of th
  • A Guide to Voltage Translation With TXS-Type Translators
    PDF, 287 Кб, Файл опубликован: 29 июн 2010
    Modern trends are driving the need for lower supply voltages across many system-level designs. As most processor voltage levels continue to decrease in the interest of achieving the lowest possible power consumption, peripheral devices maintain a need for higher voltage levels, creating potential for voltage discontinuities within a system. To remedy this mixed voltage system incompatibility, a vo
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments TXS0101DCKR
