Datasheet Texas Instruments LM36922HYFFR — Даташит
СерияLM36922H
МодельLM36922HYFFR
Высокоэффективный двухструнный драйвер белого светодиода 12-DSBGA от -40 до 85
LM36922H Highly Efficient Dual-String White LED Driver datasheet
PDF, 1.7 Мб, Версия: A, Файл опубликован: 16 фев 2016
17 предложений от 10 поставщиков
IC WHITE LED DVR 12DSBGA. LED Driver IC 2 Output DC DC Regulator Step-Up (Boost) I²C, PWM Dimming 25mA 12-DSBGA. PMIC...
LM36922HYFFR
32 ₽
Рутоника
LM36922HYFFR
38 ₽
LM36922HYFFR
74 ₽
LM36922HYFFR
Pin12
Package TypeYFF
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
Маркировка36922H
Width (мм)1.16
Length (мм)2
Thickness (мм)1.6
Pitch (мм).4
Max Height (мм).625
Количество каналов2
Duty Cycle(Max)92 %
LED20
LED Current Per Channel30 мА
Package GroupDSBGA
Peak Efficiency92 %
Shutdown Current(Typ)1.2 uA
Special FeaturesAdjustable Switch Frequency,CABC,Direct PWM Dimming,I2C Control,OVP,Thermal Shutdown
Switching Frequency(Max)1050 kHz
TopologyBoost,Current Sink,Multi-Channel
ТипInductive
Vin(Max)5.5 В
Vin(Min)2.5 В
Vout(Max)40 В
Vout(Min)37 В
  • Evaluation Modules & Boards: LM36922EVM
    LM36922 Highly Efficient Dual-String White LED Driver Evaluation Module
  • Analog PWM Dimming in White-LED Drivers
    PDF, 539 Кб, Файл опубликован: 21 дек 2016
    Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
Серия: LM36922H (1)
  • LM36922HYFFR
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments LM36922HYFFR
