Datasheet Texas Instruments SN74CBTS16212DL — Даташит
СерияSN74CBTS16212
МодельSN74CBTS16212DL
24-битный коммутатор шины на полевом транзисторе с ограничением на диоде Шоттки 56-SSOP от -40 до 85
24-Bit FET Bus-Exchange Switch With Schottky Diode Clamping datasheet
PDF, 323 Кб, Версия: E, Файл опубликован: 13 ноя 2001
Pin56
Package TypeDL
Industry STD TermSSOP
Package QTY20
МаркировкаCBTS16212
Width (мм)7.49
Length (мм)18.41
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
Additional FeaturesSchottky clamp diode to prevent undershoot
Полоса частот200 МГц
Configurationcrosspoint/exchange
ESD HBM2 kV
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)10.5 пФ
Количество каналов24
OFF-state leakage current(Max)1 мкА
ON-state leakage current(Max)150 мкА
Package GroupSSOP
Package Size: mm2:W x L56SSOP: 191 mm2: 10.35 x 18.42(SSOP) PKG
Ron(Max)20 Ohms
Ron(Typ)4 Ohms
Supply Current(Max)3 uA
Supply Range5.5 Max
VIH(Min)2 В
VIL(Max)0.8 В
Vdd(Max)5.5 В
Vdd(Min)4 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
Серия: SN74CBTS16212 (2)
На английском языке: Datasheet Texas Instruments SN74CBTS16212DL
