Datasheet Texas Instruments TPS60230RGTTG4 — Даташит
СерияTPS60230
МодельTPS60230RGTTG4
5-канальный зарядный насос с регулируемым током, 125 мА и белой светодиодной подсветкой в 3x3 QFN 16-VQFN от -40 до 85
TPS60230: White LED Charge Pump Current Source with PWM Brightness Control datasheet
PDF, 1.0 Мб, Версия: A, Файл опубликован: 25 май 2004
Pin16
Package TypeRGT
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаBIZ
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Количество каналов5
Duty Cycle(Max)100 %
LED5
LED Current Per Channel25 мА
Package GroupVQFN
Package Size: mm2:W x L16VQFN: 9 mm2: 3 x 3(VQFN) PKG
Peak Efficiency90 %
Shutdown Current(Typ)0.1 uA
Special FeaturesAnalog Dimming,Analog/PWM Mixed Dimming,Direct PWM Dimming,Enable/Shutdown,Fault Detection,Integrated Switch,Load Disconnect During Shutdown,Soft Start,Synchronous Rectification,Thermal Shutdown
Switching Frequency(Max)1250 kHz
TopologyBoost
ТипCapacitive
Vin(Max)6.5 В
Vin(Min)2.7 В
Vout(Max)6.5 В
Vout(Min)2.7 В
  • Evaluation Modules & Boards: TPS60230EVM-047
    TPS60230EVM-047 Evaluation
  • Evaluation Modules & Boards: TPS60231EVM-047
    TPS60231 Evaluation Module
  • TPS60230 WLED Charge Pump
    PDF, 70 Кб, Файл опубликован: 9 ноя 2005
    The TPS60230 is a complete solution for driving up to five white light-emitting diodes from a single-source Li-ion battery or power source up to 6.5 V. This application report breaks the part down into functional blocks and describes each of the blocks. Additionally, applications for improving current accuracy and overall efficiency, and reducing noise susceptibility are discussed.
Серия: TPS60230 (3)
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments TPS60230RGTTG4
