Линейка продуктов KEEN SIDE
Datasheet Texas Instruments ADS1250U/1K — Даташит
СерияADS1250
МодельADS1250U/1K
20-битная система сбора данных Аналого-цифровой преобразователь 16-SOIC
ResolutionPlus 20-Bit Data Acquisition System Analog-to-Digital Converter datasheet
PDF, 393 Кб, Файл опубликован: 27 сен 2000
Pin16
Package TypeDW
Package QTY1000
МаркировкаADS1250U
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
# Input Channels1
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)4.75 В
АрхитектураDelta-Sigma
Digital Supply(Max)5.25 В
Digital Supply(Min)4.75 В
INL(Max)21 +/-LSB
Input Range(Max)4.196 В
Тип входаDifferential,Single-Ended
Integrated FeaturesPGA
InterfaceSPI
Multi-Channel ConfigurationN/A
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Power Consumption(Typ)75 mW
Reference ModeExt
Разрешение20 Bits
Sample Rate (max)25kSPS SPS
Sample Rate(Max)0.025 MSPS
THD(Typ)-97 дБ
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • AB-174: Getting the Full Potential from your ADC (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 28 июн 2002
    Many of today?s high-resolution ADCs (Analog-to-Digital Converters) are operating from a single supply and use fully differential inputs. This can be a problem for single-ended signals that are bipolar relative to common. This article illustrates circuit configurations that preserve the full-scale input range by using modern features, such as Programmable Gain Amplifiers (PGAs) and internal voltag
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Interfacing the ADS1251/52 to the MSP430
    PDF, 264 Кб, Файл опубликован: 8 мар 2005
    This application report demonstrates an effective method to interface the ADS1251 and ADS1252 sigma-delta data converters to the MSP430F449 microcontroller. The software for this application report was developed on the HPA449 development system.
  • A Spreadsheet for Calculating the Frequency Response of the ADS1250-54 (Rev. A)
    PDF, 461 Кб, Версия: A, Файл опубликован: 5 сен 2003
    The ADS1250, ADS1251, ADS1252, ADS1253 and ADS1254 family of high-resolution analog-to-digital converters (ADCs) share an advanced delta-sigma (О”ОЈ) topology. This application note reviews the frequency characteristics of these devices and shows how to use a companion Microsoft Excel? spreadsheet (sbaa103a.zip), available for download from the TI web site, to calculate the frequency res
  • Digital Filter Types in Delta-Sigma ADCs
    PDF, 219 Кб, Файл опубликован: 27 июн 2017
    This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS1250 (4)
На английском языке: Datasheet Texas Instruments ADS1250U/1K
