Datasheet Texas Instruments TPS61043DRBTG4 — Даташит
Серия | TPS61043 |
Модель | TPS61043DRBTG4 |
TPS61043: Светодиодный драйвер постоянного тока 8-SON от -40 до 85
TPS61043 Constant Current LED Driver datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 2 фев 2016
![]() 14 предложений от 11 поставщиков IC LED DRVR RGLTR DIM 60MA 8SON. LED Driver IC 1 Output DC DC Regulator Step-Up (Boost) PWM Dimming 60mA 8-SON... | |||
TPS61043DRBTG4 Texas Instruments | 70 ₽ | ||
TPS61043DRBTG4 Texas Instruments | 75 ₽ | ||
TPS61043DRBTG4 Texas Instruments | по запросу | ||
Pin | 8 |
Package Type | DRB |
Industry STD Term | VSON |
JEDEC Code | S-PDSO-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | AQN |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .88 |
Pitch (мм) | .65 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Количество каналов | 1 |
Duty Cycle(Max) | 88 % |
LED | 4 |
LED Current Per Channel | 50 мА |
Package Group | SON |
Package Size: mm2:W x L | See datasheet (SON) PKG |
Peak Efficiency | 85 % |
Rating | Catalog |
Shutdown Current(Typ) | 0.1 uA |
Special Features | Load Disconnect During Shutdown |
Switching Frequency(Max) | 1000 kHz |
Topology | Boost |
Тип | Inductive |
Vin(Max) | 6 В |
Vin(Min) | 1.8 В |
Vout(Max) | 16.9 В |
Vout(Min) | 1.8 В |
- Solutions for LED Driver Overvoltage ProtectionPDF, 205 Кб, Файл опубликован: 8 июн 2009
Boost LED drivers are often used to drive LEDs in series. If an LED fails while open, overvoltage protection (OVP) is necessary to avoid the damage to a boost integrated circuit (IC) or output capacitor. This application report presents the solutions to increase the TPS61043 LED driver OVP threshold. - Design considerations for a resistive feedback divider in a DC/DC converterPDF, 393 Кб, Файл опубликован: 26 апр 2012
- Optimizing Transient Response of Internally Compensated DC-DC Converters (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 11 май 2015
- Extending the Soft Start Time Without a Soft Start Pin (Rev. B)PDF, 387 Кб, Версия: B, Файл опубликован: 15 июн 2017
- IQ: What it is what it isn’t and how to use itPDF, 198 Кб, Файл опубликован: 17 июн 2011
- Performing Accurate PFM Mode Efficiency Measurements (Rev. A)PDF, 418 Кб, Версия: A, Файл опубликован: 11 дек 2018
Серия: TPS61043 (4)
- TPS61043DRBR TPS61043DRBRG4 TPS61043DRBT TPS61043DRBTG4
- Semiconductors > Power Management > LED Driver > Backlight LED Driver
