Datasheet Texas Instruments OPA544FKTTTG3 — Даташит
СерияOPA544
МодельOPA544FKTTTG3
Высоковольтный сильноточный операционный усилитель 5-ДДПАК/ТО-263
High-Voltage, High-Current Operational Amplifier datasheet
PDF, 883 Кб, Файл опубликован: 27 сен 2000
Pin5
Package TypeKTT
Industry STD TermTO-263
JEDEC CodeR-PSFM-G
Package QTY250
CarrierSMALL T&R
МаркировкаOPA544F
Width (мм)8.42
Length (мм)10.16
Thickness (мм)4.58
Pitch (мм)1.7
Max Height (мм)4.83
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)90 дБ
CMRR(Typ)106 дБ
GBW(Typ)1.4 МГц
Input Bias Current(Max)100 pA
Iq per channel(Max)15 мА
Iq per channel(Typ)12 мА
Количество каналов1
Offset Drift(Typ)10 uV/C
Output Current(Typ)4000 мА
Package GroupDDPAK/TO-263
Package Size: mm2:W x L5DDPAK/TO-263: 155 mm2: 15.24 x 10.16(DDPAK/TO-263) PKG
Rail-to-RailNo
Slew Rate(Typ)8 V/us
Total Supply Voltage(Max)70 +5V=5, +/-5V=10
Total Supply Voltage(Min)20 +5V=5, +/-5V=10
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • DC MOTOR SPEED CONTROLLER: Control a DC Motor without Tachometer Feedback
    PDF, 50 Кб, Файл опубликован: 27 сен 2000
    DC motor speed is often regulated with a closed-loop speed controller using tachometer feedback. It is possible, however, to control dc motor speed without tachometer feedback.
  • MTTF, Failrate, Reliability, and Life Testing
    PDF, 51 Кб, Файл опубликован: 4 окт 2000
    At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
  • Building your own Battery Simulator
    PDF, 114 Кб, Файл опубликован: 14 окт 2013
    Building your own Battery Simulator OPA544, bq2409x, bq2404x, bq2415x, bq2425x, bq2416x
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA544FKTTTG3
