Datasheet Texas Instruments SN74AHCT16244DGVR — Даташит
СерияSN74AHCT16244
МодельSN74AHCT16244DGVR
16-битные буферы/драйверы с выходами с 3 состояниями 48-TVSOP от -40 до 125
SN74AHCT16244 16-Bit Buffers/Drivers With 3-State Outputs datasheet
PDF, 812 Кб, Версия: J, Файл опубликован: 13 окт 2014
Pin48
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаHF244
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
Bits16
F @ Nom Voltage(Max)110 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)-8/8 мА
Package GroupTVSOP
Package Size: mm2:W x L48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) PKG
Schmitt TriggerNo
Technology FamilyAHCT
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)9.5 нс
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
На английском языке: Datasheet Texas Instruments SN74AHCT16244DGVR
